Quote Originally Posted by munday63
Hi, i have a set of 5 speakers and a subwoofer with simple 2-wire connections at each end and i was wondering if anyone knew where i could pick up a cheap dvd player for these speakers?
Also i was wondering if anyone knew the techincal name for the clips which you have to connect the cable to?
Thanks
You're need a receiver to go between the DVD player and those speakers. Even then, it's not likely your subwoofer would work without yet another amplifier.
