Quote Originally Posted by BigVic
upgraded my sub cables.taking the old cable off but I also took off the gold plated part of the rca output.I carefulysnapped it back into the output,and did a sound check with the sub.It seems to be ok.Any advice would be of great help.
So, what, exactly, is your problem? If it's working you have no problem.
Here's a tip for the future: When removing RCA plugs from RCA jacks, do NOT pull/yank them off.. Gently twist them and, when they loosen, you can gently pull them off. You've seen the results when you use brute force to yank 'em off ...and got lucky that it still works.
