Results 1 to 5 of 5
    Oct 2003
    Grand Rapids, MI
    A question about corner bass traps
    I am wondering if I can cover a corner bass trap like this with fabric to match the color of my room. I don't want to compromise their effectiveness.
    http://www.moldingsbest.com/CornerSolutions.html
    what type of material would work best?
    TV-Panasonic CT-27L13
    Receiver-Pioneer Elite VSX-14
    Main Towers-Infinity RS-5's
    Subwoofer-Infinity SW-12
    Center Speaker-Infinity CC-3
    Surrounds-Infinity RS-3's
    DVD Player-JVC XV-F80
    DVD Recorder-Philips DVDR75
    Dec 2004
    Santa Rosa, CA
    Speaker grille cloth should work fine, it's a very open weave fabric. Don't stretch it tight enough to collapse any of the foam.
    Madisound carries it in brown or black at $7.00 yard. Most probably Parts Express has it as well.
    Aug 2002
    Probably, the cloth won't impair the effectiveness of the traps.
    Here's a link to more info regarding room treatments.
    http://www.realtraps.com/data.htm
    SF Bay Area
    As others have said, the fabric won't affect the performance of a bass trap. Fabrics are typically not reflective enough to affect the low frequencies, so just go with whatever matches. With acoustic panels designed to absorb high and midrange frequencies, then the type of fabric used does matter more because tight weaves and dense fabrics can reflect higher frequencies more than looser and more transparent fabrics. Other DIY bass traps I've seen use burlap material.
    Make your own
    Very good link to make an effective bass trap by Jon Risch. I have made some of his pannels for my side walls and have had good results.
    http://www.geocities.com/jonrisch/
    have fun
  1. Need help understanding room effects on bass response (Wooch?)
    By kexodusc in forum Home Theater/Video
    Last Post: 02-10-2005, 05:52 AM
  2. RGA Reviews Page 3 - yes still more.
    By RGA in forum Speakers
  3. Replies: 6
    Last Post: 08-09-2004, 07:43 AM
  4. Subwoofer placement vs. room modes (standing waves)
    By Richard Greene in forum Speakers
    Last Post: 02-27-2004, 05:40 PM
  5. Dual sub-woofers??
    Last Post: 02-22-2004, 12:26 PM
