Page 12 of 14 FirstFirst ... 2 10 11 12 13 14 LastLast
Results 276 to 300 of 332
  1. #276
    Sophisticated Red Neck manlystanley's Avatar
    May 2008
    In Old Pickup Truck, Cruising Hickville
    You would want to put something on a couple of the walls to absorb sound in order to keep the reflections and reverb down. I know that's difficult on concrete. You could try a heavy curtain from the ceiling sort of against the wall.
    Get yourself one of these bad boys:
    http://www.homedepot.com/webapp/wcs/...5X-_-202046595
    I bought mine off of craigslist for $30. Makes driving nails into concrete fun..... When I put up my sub-panel fuse box in my basement (I ran a 60 amp line from the main box to the basement) I attached a big piece of plywood to the Concrete wall. Then attached the basement fusebox to this piece of plywood. It works like a champ. Use glue as well and you can hang what ever you want on it.
    Best Regards,
    Stan
    Listening/Movie Room: ADCOM GTP-500, XPA-2, Denon 3930ci, Front: Jamo C809; Surround: Klipsch R-5650-S; Back: R-5650-S; Denon AVR-687,. Projector: Sharp XR-32X.
    Family Room: Denon avr-687, Denon CD player, Klipsch RB-5II
  2. #277
    Dallas, TX
    Quote Originally Posted by IRG
    So I got the AT cartridge last night, opened the box (not the container holding the cartridge itself) and discovered one of the four pins looks significantly bent. I could straighen it out I suppose, but I imagine this could easily break off. This happened to me with a tube I bought for my guitar amp, just touching one of the bent pins and it fell off.
    I got it new from Garage A Records as recommended here. Not their fault, but if they had just eyeballed it, they would have seen this one was not acceptable to ship out. Now I remember all of the "fun" little nuances it takes to be a vinyl fan. Not.
    Inside the plastic box there should be an L-shaped adapter with four pin receivers. I'd probably try to slide it onto the bent pin and straighten it. You could ok that with the seller before you do it. Here's how I mean...
  3. #278
    IRG
    IRG is offline
    Forum Regular IRG's Avatar
    Upstate
    Well I wrote to them this a.m. and they wrote back quickly, apologized, and they're sending a new one out to me. Nice customer service, I do appreciate their efforts here. I'm sure I'll be back as a result.
  4. #279
    Dallas, TX
    It's nice that these sellers are relatively small...perhaps even only one person, sometimes. It's not like buying something from bestbuy.com (no offense intended to big box stores).
  5. #280
    Jan 2010
    ok harmon international sells referb recivers and intergrated amps cheap,also polk does the same.thay come with warranty.ive done it with polk and at less than half price,very satisfied
  6. #281
    Jan 2010
    Talking
    Thanks LeRoy, those Mordaunt Shorts look really nice, good price too, I've booked marked them for sure. I was checking out the CA 30's you mentioned, is that price per pair or single speaker? I wasn't sure, but at $220/pair, I would consider them too. Are the Polk Rti4 or TSi100's from Cruchfield pretty good speakers? Prices on both of these are good too.
    the polk tsi line r good.u can by direct rfon polk,factory referb with 2 year waranty::
  7. #282
    Jan 2010
    I would jump on these NHT Classic 2's from audiogon.
    http://www.audiogon.com/cgi-bin/cls....HT-Classic-Two
    Nice warm sounding speaker with excellent midbass.
    And here's a pair of PSB B-25's, a much better speaker than the B-15's for bass
    http://www.audiogon.com/cgi-bin/cls....291&/PSB-Image
    Or these Vintage B&W's- http://www.audiogon.com/cgi-bin/cls....ilkins-DM-1400
    http://www.audiogon.com/cgi-bin/cls....3243&/B-W-610i
    have b&w 610i bought on ebay 4 152.00 delivered nice bass 4 book shelf.from eAuction wizard.com
  8. #283
    IRG
    IRG is offline
    Upstate
    V rod,
    I pretty much have my system put together now (until I begin planning any upgrades ) Speakers are the Mordaunt Short Avant 902i, Onkyo TX8555 receiver, Yamaha DVD S1800 for cd player, and a used Technics SL-Q20 for turntable, with Audio Technica 311EP cartridge (in process of getting a new one). Only thing I'm lacking are the speaker stands. Audioadvisor's shipping is slow.
  9. #284
    May 2009
    Helotes,TX
    Hello IRG...
    Just checking to make sure that you have the speakers connected correctly. The outer speaker posts are the LF and the 2 inner speaker posts are the HF.
    You should be getting more than just bass from the 902's. How are you liking them so far?
    LeRoy
  10. #285
    IRG
    IRG is offline
    Upstate
    Quote Originally Posted by LeRoy
    LeRoy
    I think this is right, according to their manual:
    I really like them a lot. Bass is very strong. But I need the proper stands, right now, just on the floor, so I haven't done any critical listening yet. THe Onkyo receiver seems like a good match with them. I just read a review in Stereophile about the Onkyo 9555 or something like that. Integrated amp, but it seems like it has most of the same features as the 8555 receiver, minus the tuner. ANd it was really well reviewed, compared favorably to their other amps in the $2500 range. Might upgrade to a tube amp someday, for now, it is more than decent. I might try a pair of the BJC biwire cables to compare.
    But yeah so far, these are very impressive speakers, period, not "just for the money". Glad I listened to ya
  11. #286
    Glad to hear you like the Speaks and receiver IRG. Are those Blue Jeans speaker cables I see there? I recognize the shrink wrap on the banana plugs. By the way, that Onkyo 9555 integrated amp is a digital amp, completely different than the 8555.
    IRG
    IRG is offline
    Upstate
    Yep, Blue Jeans. First time I "put a cable together" myself. LOL. not much to it really. They came out pretty nice I thought, very affordable.
    I was thinking the two Onkyo amps were more closely related, they both have the WRAT signature on it, wide range whatever. The 9555 is a class D then, is the 8555 an AB design then? Seems to have a lot of power, I've had the whole house shaking (in a good way) with just these little speakers.
    Pic of the cable work:
  13. #288
    Yes the 9555 is Class D and the 8555 is AB. That 8555 is pretty nice and a high current design at that. Its pretty amazing at how inexpensive 2 ch receivers are. They are pretty good for midfi for 2ch. Better than going with an inexpensive AVR.
    Those BJC speaker cables are a bargain if you terminate them your self. I have a pair and I don't know why anyone would spend more for 10-12g wire. They sound great.
    IRG
    IRG is offline
    Upstate
    Wink
    So what would be a "significant" upgrade for the amp? About the best I've owned in the past is a Roksan Kandy integrated amp, it was good, but I can't recall it being that much better than some of the other mifi stuff I've owned. But maybe I'm not a critical listener. Not back then, maybe now I will be. I've spend an inordinate amount of time and some $ tweaking my guitar tone. Now I guess I'll move that obsession over to 2 channel sound.
  15. #290
    If your on a budget and want to go separates, consider Emotiva, NAD, B&K reference series (the later 2 amps have a warmer presentation) Parasound Classic, Outlaw Audio, used Van Alstine amps, and check audiogon for good deals on some higher end used amps. If you want the tube sound consider a tube preamp or hybrid preamp. Vincent Audio makes a very affordable hybrid tube preamp for about $450.
    For integrated amps, look at Cambridge Audio, NAD.
    LeRoy, do the MS have straps if not biamping?
    IRG, are you bi-wiring?
  17. #292
    IRG
    IRG is offline
    Upstate
    No, not now. The pic above is how I have it wired right now, according to the instructions. But I may try a BJCable (Canare) and do the biwire option, we'll see. I imagine if it would make any difference, it would probably come with a different amp and biwiring.
  18. #293
    IRG, you should sit back and listen to your system once it's up and running like you want before thinking upgrade. If you notice a weakness any where then at least you'd know what direction to go. Right now your system is balanced as far as no one piece being far out of class with another. When you get the upgrade bug it will most likely be a ripple effect. I personally believe one needs the best source possible because if the detail don't come off the disc or LP then nothing we do after that will allow us to hear it because it's not there.
  19. #294
    What he said!
    IRG
    IRG is offline
    Upstate
    I won't be upgrading, not for quite a while. Gotta enjoy it for a while, before I muck it up again. I'll work on room acoustics though, that needs the most help.
  21. #296
    Shame about the cart. Please post when your deck is up and running...
  22. #297
    IRG
    IRG is offline
    Upstate
    So I just got an email from Audio Advisor that my speaker stands have shipped out. Today. 7 days after I ordered them. $50 stands, $12 in shipping, and it took them a f*&king week to ship them out. Wow, what wonderful crappy customer services. First, and last time I order anything from them. AC4Less was awesome btw, as was Needledoctor.com and the Garage A Records where I got the damaged cartridge from, they were awesome in their service too. But AA bites the big one in my book.
  23. #298
    I ordered my Parasound from AA and it shipped out the next day. I find that buying on the internet is so variable except for BJC which ships out the next day.
    IRG
    IRG is offline
    Upstate
    They may not have had this item in stock. Which kinda sucks, because had I known this, I wouldn't have ordered from them. It turns out another website had these same stands in stock, but when I placed my order, they let me know that it was actually out of stock. Nice of them, even though they did lose the sale. But I would shop that place again. AA was deceptive, because they sent the initial email, saying thanks for the order, yada yada.
    BJC was great. AC4less was really good too, I was impressed (and initially a little worried). Very professional outfit I found.
  25. #300
    May 2009
    Helotes,TX
    Hello IRG and Mr. Peabody....
    IRG, you've got the speakers hooked up correctly. If you want a better jumper than the silver hand cuff looking jumper's that come shipped with the speakers I have a very affordable solution for you.
    Simply go get some solid core copper wire that is OFC....the 99.99999% type..you know what I mean there....and use the silver jumpers as a measure for cutting a strand of the solid core copper, then strip the insulation off the SCC, mark the ends of the SCC as you want to take a pair of pliers and bend the SCC ends into a hook shape, not circular, hook the posts, and then you have essentially a bi-wire configuration without spending any more big bucks.
    Mr. Peabody, I am not sure what you mean by straps. The photo that IRG has of the rear of the 902's...you can see the silver jumpers that come with the speakers. I call them jumpers and maybe you call them straps?
    As far as be able to bi-amp them, they can be bi-amped but there is no special bi-amp connection on back of the speaker cabinets...they just get bi-amped in the usual way.
    Hope this info helps. Enjoy the music.
    LeRoy
There are currently 5 users browsing this thread. (0 members and 5 guests)
