Results 1 to 25 of 332
    www,amusicdirect.com used to carry a lot of Marantz. You were probably talking about a local shop though. The Yamaha DVD player may be fine though. If it meets your needs give it a listen. What ever pieces you go with you might want to stick with the ones that will accept a return and with no restock fee, in case you get something you just can't live with.
    IRG
    IRG is offline
    Forum Regular IRG's Avatar
    Upstate
    Well now, the Marantz gear does look pretty good, a definite step up from the Yamaha or Onkyo stuff. I like this receiver here" http://cgi.ebay.com/Marantz-SR4023-8...item1c0f660a1a
    It's stretching the budget though. Tempting it is...
    Dallas, TX
    Quote Originally Posted by IRG
    You could have had a Marantz SR4021 for $219 from accessories4less if you had jumped on it when I linked to it in post #23 of this thread...
    IRG
    IRG is offline
    Upstate
    I thought about it. Probably not an issue, but the frequency range was 40hz-20khz, and I dunno, something about a receiver that doesn't do 20 -20 bothered me, but not like any of these speakers I'm looking at would be affected. The newer version addresses this apparently. O think ac4less has the 4023 for $299. Not bad either.
