For $79 its worth a look. If you don't like it your only out $79 and can buy something nicer when you have more money. I would get some decent IC's like bluejeanscables for $30pr. I'd put the money saved to a Harmon Kardon receiver.
I'm leaning towards the Yamaha RX-397 at the moments, this one here: http://www.crutchfield.com/p_022RX39...97.html?tp=179
Seems to get really good reviews everywhere. Which Harmon Kardon would you recommend over the Yamaha? Also, if I went with the Yamaha receiver, it should be able to control that Yamaha dvd player too I would think, at least basic controls, which would be enough.
Is the QC with HarmondKardon good these days? Always seemed to be an issue as I recall years ago. I currently have a NAD 5 channel receiver in the living room, nothing fancy at all, but this thing gets used for hours a day, and has been great overall. If I could find a good affordable NAD I would go that route too. But something about the Yamaha receivers I've always liked too.
Also leaning towards the Denon 300F turntable at the moment. For $300, or maybe less, I don't think I can beat that. Upgrade the cartridge later.
Edit, I see the HK 3390 you mentioned earlier, checking it out now at Amazon...
