Onkyo SP504 and SP1000 need advice
Hi everyone, I'm new in the community.
For those who are familiar or have used either or both products, is there a significant benefit moving from the SP504 to SP1000 if my primary goal is hi-res audio, mostly SACD playback? Both units sport the same 192/24 audio DAC but of different make, Cirrus Logic vs Wolfson. The overall build quality of the SP1000 is superior but do you think there's a significant difference in audio performance to justify the cost difference? I'm using the A-9555 as int amp.
Thanks for your valuable feedback and opinion.
