Results 1 to 25 of 46
    Ajani
    Quote Originally Posted by hermanv
    I used to own a $1799 NAD surround receiver, I had 1st class speakers (about $5K worth) and try as I might and no matter how hard I wished, the sound was never as good as my dedicated 2 channel system. I also used to own an all Denon system (about $3K worth), again I couldn't get the 2 channel sound quality I was striving for.
    So while I have certainly not heard all brands of receivers, my personal experience is that this a a hard way to go if true audiophile sound is your goal.
    Many well regarded stereo only people now make 2 channel integrateds or pre-amps with a bypass system to avoid duplication of expense but still allow a good mix of quality 2 channel and surround sound.
    Would you have paired a NAD C372 Integrated Amp ($1K) with $5K Speakers? The best you should really hope for in a NAD surround receiver is sound on par (though most likely less) than their top battleship grey integrated amp...
    A HT Receiver is essentially an integrated amp with a pile of processing features for both audio and video & at least 3 times as many channels of amplification... Thus I never expect a HT Receiver to sound much better than an integrated amp for half its price....
    You can definitely get a great sounding HT Receiver or Pre/Pro & Multi-Amp combo... you'll just have to spend about double what you would on an integrated amp...
    Dec 2004
    Santa Rosa, CA
    In this case the primary use was home theater. I needed an AC-3 and PCM decoder and I had nice rear and center channels speakers.
    There was little point in using the system for 2 channel, as I already had a dedicated set up. I would put the home theater set up into straight stereo mode for comparison, no processing, room enhancements or sub woofer (my main L/R speakers were good to 22Hz), I just expected sound that was close to my main system, if a little less refined, from the HT set up. I didn't get it.
    The Denon was a 2 channel only set up. It had that etch, glare whatever you call it, a roughness with maybe a touch of white noise thrown in, centered at what sounded like 3KHz. What was sometimes called a transistor sound. By comparison the NAD had far less of this problem, it's main short coming was a muddling of sound, a lack of clarity, while somehow maintaining significant tweeter energy.
    The closest I've heard to good stereo from an HT set up was the Outlaw, fewer negatives still, little or no improvement of the positives.
    I realize budget is an issue and a good receiver system will still beat an iPod or Bose table radio hands down. A carefully chosen system will also beat the mass market "package" deals.
    Herman;
    My stuff:
    Mark Levinson No.360S D to A
    Cardas Golden Presence IC
    Pass Labs X250
    Martin Logan ReQuests.
    Hmmm. All the HT Receivers I've seen are receivers. While I don't know anyone who uses the AM/FM tuner section (never used mine), they do nevertheless have one.
    I, too have a NAD unit (T763) that sounds pretty decent. While it doesn't have the refinement of the main system, it is still pretty neutral sounding. Since I'm a speaker guy, I could easily imagine driving some Maggies with it.
    Dec 2004
    Santa Rosa, CA
    My NAD was also a T76?, did they make a T765? That sounds right. I think it was 70 or 75 watts/channel all channels driven. about 110 watts for stereo.
    I certainly never meant to imply it was junk, if I wasn't an audiophile nut, I'm sure it would have been just fine.
    Herman;
    My stuff:
    Pass Labs X250
    There were many 76x receivers. Look here. The 763 does 100 watts all channels driven.
    I didn't take your comments that way. I'm an audio freak, too.
    Mutant from table 9
    Mar 2005
    Another thought to throw into the mix is the use of AVRs with separate amps. I have what a consider a decent mid level system: Yammie RX1500 with Yammie M-65 amp. I added the amp for two channel stereo. With the Pure Direct feature the AVR just becomes a straight preamp gain stage. Have I not just created a separates system for less than $1200? Plus, when I do wan't to watch a movie, the AVR is still right their to do the processing.
    ______________________
    Ajani
    Yep... you've essentially created a seperates system for under $1.2K... That's a pretty common practice now... another one is to get an integrated amp with HT passthrough in place of the M-65....
    Since I'm a 2channel guy, I'd just opt to spend the entire $1.2K on either an amp/pre combo or an integrated amp, rather than have part of my budget spent on the Tuner (thanks E-Stat), extra channels of amplification and all those audio/video processing features....
    This is the most popular (and probably best) way to have a "hybird"
    system that can do double duty , both HT and stereo, certainly the most
    inexpensive and convienent.
    AS for FM I too dissed it for a long time, until I heard an actual, commercial JAZZ station on my car stereo.
    So I set mine up, sounds quite good.
    ALSO I have noticed that surround receivers tend to sound better when you use all channels, dont sound quite as good in stereo
    Dec 2004
    Santa Rosa, CA
    You made me look, found old paperwork it was a T770. Funny, manual on the site you listed seems to be missing any specs such as power/channel.
    Herman;
    My stuff:
    Pass Labs X250
    Ajani
    LOL... my bad... I forgot to mention the tuner... since a Receiver is an Integrated Amp with a Tuner...
    I guess it should be obvious how often I listen to the radio (apart from in my car - hmmm, just about never)....
    Feb 2003
    Los Angeles, CA
    My pre/pro has a tuner, though it's not a touted feature. I don't use it or need it, but there it is, sitting unobtrusively for the most part.
    When I moved, I hooked the pre/pro up to a two channel amp and used the tuner as the source while I put everything together. It was actually one of the better tuners I've used in terms of pulling stations and providing excellent FM sound. Still, without an analog signal strength meter, center tuning meter, and an illuminating STEREO light, it just didn't seem right. It's merely a digital readout on the LCD screen.
    I don't think I've listened to it since.
    FM radio seemed like an "audiophile" experience to me when I used to listen to Texaco Presents the Metropolitan Opera on the old Magnavox console as a kid, but it doesn't seem so anymore. Maybe HD radio? Haven't tried it.
    I like sulung tang.
    I could have worded my observation a bit more tactfully. Should have included a smiley face.
    Speaking of unused features, how many folks actually double up on the cable runs just to switch the video through the receiver?
    Sgt. At Arms Worf101's Avatar
    Troy, New York
    Errrrr...
    When your ole lady's as "technically challenged" as mine, if you can make the process of switching from DVD to TV a "one button process" by doubling up on your cables, you do it.
    Da Worfster
    Ajani
    Da Worfster
    Personally, I'd rather use a Logitech Harmony remote.... so when she wants to watch a DVD, she just presses DVD and everything that should be turned on is turned on and switched to the right settings (oh, and the DVD begins playing)... and when she needs to watch TV, the settings change and the cable box comes on... (depending on how much you spend to double up cable, the Logitech may be a cheaper option)....
    Sounds like a neat solution. I'm more averse to increasing the already busy collection of cabling. In my household, wifey is more the video champ so she's adapted to the three remote scenario (cable is third).
