If it's not large and the hole isn't gaping, you may be able to seal it with some clear fingernail polish. The cone is a paper material so if it's rot you may be looking at a replacement soon. Some woofers can be reconed but you'd have to check with E-V or online to see if kits are available to that. Or, most electronics services centers offer the service and may know if it can be done.
the last picture i posted shows the hole at the bottom of the picture. it's not large, but it's more of a hole than a tear. i believe the little piece of material that was taken out to create the hole is still hanging on... should i close it and then cover with the nail polish?
EDIT: here's another pic. Everything looks fine to me aside from the minor tear.
