Results 1 to 8 of 8
    Jun 2015
    Need recommendation for simple FM radio to plug into my Vizio soundbar
    I need a simple solution to a problem. I bought a Vizio soundbar for my HDTV and love it. I also use it to play music from my iPhone. But I still would like to have FM radio to play through it for a local station I live that plays oldies. Anyone have a suggestion on a cheap radio or receiver I could purchase to give me this capability?
    What type of inputs do you have on the sound bar? You should be able to find a stereo tuner for cheap at your local pawn shop.
    Jun 2015
    Inputs on the soundbar are:
    Optical (Digital)
    Coaxial (Digital)
    Analog Audio (2 of these)
    USB
    Quote Originally Posted by sandy_bauer@yahoo.com View Post
    Optical (Digital)
    Coaxial (Digital)
    USB
    You should be able to connect the tuner to the analog inputs as long as the Tuner has RCA jacks or cables.
    Since you already use your phone, there is a radio ap you can download. I can't remember the name but our local Rock station advertises it so you can listen and not run your battery down.
    If your area has a lot of stations you might search Amazon for a HD tuner in order to pick up the extra digital stations regular tuners can't get.
    If only interested in the one you mentioned I'd probably check like Craigslist or similar for something used for not much money.
    If you already have a radio with headphone jack just buy a connecter where one end fits the headphone jack and the other the analog input of your Vizio and you are in business.
    Pass Labs XP-10 preamp
    JBL 4367's & SAM3ha
    You could also buy a cheap 2ch Onkyo receiver like this one-
    http://www.amazon.com/Onkyo-TX-8255-.../dp/B001AMSPQI
    Tuners are among the most durable of hi-fi components and at the same time demand for them is declining: that makes used tuners are great deal. There are innumerable choices on eBay ... e.g. Sony FM Stereo Quartz Digital Synthesizer Tuner ST JX521 FM AM Tuner VGC | eBay
    The vizio already has power so a receiver really would not work for this application.
    JBL 4367's & SAM3ha
