Buy a higher end CDP like a Rega Apollo, Cambridge audio 740c, Marantz SA8001 SACDP. If these are too expensive then look at the Cambridge AZure 640c, Music Hall CD25.2 and eventhe Marantz 5001. These will give you more of what your looking for. A higher end amp will help as well. Are you looking for 2ch or multichannel HT. If 2ch, then you could look into the outlaw audio RR 2150 receiver for $650 or an integrated amp like Onkyo or Cambridge audio. If your receiver has a preamp out you could look into a pair of the outlaw monoblocks for $650 a pair or a B&K reference sereis 125.2 amp for abour $699. There are many options available depending upon how much you want to spend. The B&K amp can be found at www.audiophileliquidators.com and www.depedableaudiovideo.com The cambridge CDP's can be found at the last address at excellent prices. www.hcmaudio.com carries the music hall.
By the way, don't waste your money on fancy power cords and conditioners. IMO and professional reviews they dont make a rats ass of a difference and they won't give you what your looking for.
Hope this helps some. I'm sure others will give some feed back as well.
