Results 1 to 8 of 8
Threaded View
    Feb 2004
    Need help choosing Speakers/Amp
    Hi,
    I am looking at buying a system for my bedroom which is pretty small (about 5mx5m) and am having trouble deciding what amp/speaker combo to get.
    I have looked at the following speakers
    -Sonus Faber Concertino
    -Paradigm monitor 5 v4
    -Paradigm focus v4
    And the following intergrated amps
    -NAD C-320BEE
    -Rotel RA-04
    -DENON PMA-1055
    and just a cd player/dvd player as a source.
    I normally listen to 80s,rock,pop,jazz so subwoofer may be needed
    My budget is about us$2000 but can afford more/less if required.
    Oh im sound deadening the room also with acoustic foam - will I just need to use it on the opposite wall to where the speakers are or all corners / roof???
    Cheers
    Mike
