A midrange distortion problem
Hello!
I bought not long ago a very basic setup for my HT. It consists of Yamaha HTR-5730 receiver, 2 JBL's E80 and a E150 subwoofer. I noticed that JBLs are 6 ohms and the receiver specifies "6 ohms minimum", so all correct here. Also receiver delivers 100W per channel and the E80s rating is 100WRMS (400 peak) so no problem here either.
Okey, so my first test was Matrix Reloaded :) In the middle of action (in especially loud explosion) the receiver cuts the power and displays "Check connections", I verified them they are all hooked properly... But the problem is that after that unfortunate accident the midrange speakers started to produce a noticable amount of distortion... But only the midrange ones! I always thought that the first to go will be the tweeters...
So finally :) my question is: what is the problem? Should I remplace the midrange speakers? Or maybe it's the crossover that is burnt out?
Any suggestions are welcome!
Thank you in advance!
A.H.I.
