I can't argue with you there as it seem compression problem have gotten worse. But that still does not win argument as to superiority of vinyl over CD. If a CD remastering is done right, vinyl can not touch it in terms of dynamic, noise and frequecy response.
David Bowie CDs from Rykodisc is good example of how wondefrul CD sound is when remastering is done right.
In my experience, the quality of the playback might be as simple as the choice of playback rig used during the mastering process. After doing a bunch of listenings and comparisons with Mobile Fidelity's SACD and LP releases versus other versions for specific titles, I just get the impression that they get their releases to sound so good simply because they use a highly customized reel-to-reel player during the transfer process. Their analog chain purportedly measures flat all the way up to 100 kHz, and every component in that analog sequence is custom built. They like to tout the gold substrate on the discs and how they do the bitmapping, but to me, differences in digital equipment pale in comparison to differences in the analog domain.
Comparing the SACD and CD layers, I notice a slight difference, but even the CD layer on Mobile Fidelity's Gershwin release subjectively sounds better than the 96/24 PCM version that I have from Classic Records.
