Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By StevenSurprenant
Thread: Info for tripath owners
    Apr 2002
    Illinois
    I've been busy with new interests, butI thought I'd drop line about what I believe some here might find interesting and useful.
    One of my new interests is a new Meade telescope that I picked up. It is an auto-tracker and needed a power supply for those times when I am away from a power source, so I bought a car jump starter for that purpose. (Stay with me...)
    My stereo amp is a Trends TA10.1 digital amp which puts outs out about 6 watts. That is more than enough for my speakers and the room they're in. Many times I had read an article at 6moons (web site – link below) about using battery power with this amp. I now had the battery power to do this so here are my results...
    6moons audio reviews: Trends Audio TA-10
    There was a significant drop in the noise floor which resulted in a major increase in audio quality. While I thought it sounded very good before, it transcends that by a very decent amount. There is now more detail and more air around instruments. In addition, the stage is more defined and the background instruments/singers are as clear as the foreground instruments/singers. Keep in mind that this is all relative to the before and after. To make a long story short, from this point on, battery power is here to stay and I doubt I will ever use the power supply that came with the amp again. In my system, this amp is magic and put several class A (expensive) amps to shame in terms of clarity and soundstaging.
    To give you an idea of the change, for years I had a favorite recording that I played hundreds of time, so I knew it very well. There was one cut that starts off with whistling,but on battery power, I could hear the whistling begin before the song actually started. It was extremely clear, but at a very low level. In all the times I've played this song, I had never heard this before. In the past I would have considered spending a serious chunk of change for an improvement of this degree and all this cost me was the wire to connect it to my battery. So there you have it...
    There are a few people that use tripath amps (digital), so hopefully these people will find this posting of use.
    While I'm here I want to mention two other things...
    First, I made the transition back to vinyl. I picked up a 30 year old Denon turntable (like new), fitted it with a Audio Technica AT120E cartridge and bought an ART phono preamp. The results have been astounding. The total cost was about$550. Rather than spell out the differences between vinyl and CD's, I'll just say that I haven't touched a CD since.
    The last thing is that I built my own speakers from used (never actually used) parts that I bought for a very decent price. I built my own boxes and the total cost for the completed set was about $800. I always had an affinity for the very best audio and one of my systems cost me around $15,000. Most systems I liked cost a great deal more than this. This system($1,600 total) does not leave me wanting in any way. While there is always better (in one way or another), I lost all interest in upgrading. In the past I couldn't drive past an audio store without pulling in, but now I don't give them a second look.
    The point of the last two paragraphs is that good audio doesn't have to cost an arm and a leg. This just points out how I achieved that goal.
    Well, I'm back to my new interests and I'll see you folks on the net sometime.
    JohnMichael likes this.
    Glad you have achieved some real performance gains. I have yet to try a battery supply but have read the reasons for the benefits. I do filter and surge protect my lower voltage components but it is not able to handle the Krell S-300i. I have purchases power supply upgrades for my phono preamp and turntable. Those changes have proven to me the benefit of cleaner more stable power. I would think battery power would remove even more noise. Good job.
    Welcome back to vinyl. I prefer vinyl and use cd's for convenience. One thing I discovered for myself and later read in Absolute Sound was to turn off cd players when listening to vinyl. AS states that digital noise can bleed into the preamp and low level signal. I have enjoyed the hands on experience tweaking and setting up my turntable.
    If you would tell us more about your speakers. I am considering several options for a pair of speakers. I have three pair of speakers that I listen to routinely and a pair I rarely have in the mix. I would be interested in learning what aspects of performance were at the top of your list when you built them.
    Apr 2002
    Illinois
    John,
    Since you asked,
    I used a pair of NewForm R45 tweeters. I had heard NewForm speakers and really liked the tweeters. The model of NewForm I had heard sounded good, but there seemed to be a disconnect between the tweets and the woofers so I opted for different woofers.
    NewForm
    I used SEAS W18EX001 woofers (one per box). They were the ones that the fellow had for sale.SEAS EXCEL WOOFERS
    I built the box out of Baltic Birch and used sound deadening material inside.
    I also used Mundorf Silver-Oil capacitors for the crossover, which helped the sound a lot. I had tried several different capacitor brands, but these really shined. The coils I used were nothing special.
    Like I said, I got the parts used for a very low price.
    I crossed these over at about 1,000Hz which is where NewForm recommends the ribbons be crossed over.
    I should note that the SEAS magnesium woofers have a resonance at about 5kHz so crossing them over at such a low crossover point pretty much took care of that. If I used these woofers at a higher crossover point, I would have to include a notch filter to drop that peak. I tried a number of different crossover point and even a notch filter, but in the end, I just went with a 6db slope for both the woofer and the tweeter. It sounds good enough.
    The woofer only goes down to about 55Hz so a sub is needed if I want to go lower. If I were buying the parts new for full price, I would probably get a SEAS W18E001 (No X) as they can go lower, but I'm not complaining.
    This was my first speaker build and I had no plans for the box or the crossover, so it took a little bit of reading and testing to make it happen. I got lucky! Also, these are not for everyone because they are over 6 feet tall and tipsy. They do produce a very nice sound field.
    From linkwitzlab: “A most remarkable driver is the SEAS W18EX001 because of its excellent linearity “
    Midrange distortion test
    Here's a version that uses the SEAS W18E001: SEAS TJL-2W
    Here's even more: DIY Loudspeakers constructions
    Here's more directly from SEAS: SEAS DIY KITS
    There are other great drivers if you're serious about building your own. I hope this helps.
    As for what's important to me in sound, it's all about images hanging in 3D space, the space between them, and with only the recording limiting the apparent depth of the stage. I like enough clarity to hear a singers lip smack when they open their mouth to sing or hear background sound just as clear as the foreground. Micro details are very important because they can make a voice or instrument go from good to more real. Actually, that's what I got when I went to battery. Sounds that were masked before on AC power were now audible and added to the clarity and vibrancy of the sound.
    What's not as important to me is bass extension. If the bass is not right, it's better to be without. At some point I'll add a sub to my system and I'm thinking Rythmik Audio (servo sealed sub). I have a HSU which is great for surround, but for music, I prefer something better. In the future, I might rebuild my speakers and build a sub to match, to make them a little nicer looking. It would be an act of joy to do so.
    I have one final thought...
    The gentleman who sold me these speaker drivers will never know how grateful I am to him. They have brought so much entertainment and joy to my life, at a cost I could afford.
    I'm glad to hear about the NewForm drivers. I've been intrigued by them for a long time but wondered about the issue of integration with the mid-bass; crossing over between very different drives exactly in the middle of the audio spectrum, 1000 Hz, seems a tricky proposition.
    Seas Excel woofers (and tweeters) have superb reputation but of course they are very expensive. The Thor design doubtless gives a great result but, again, at very high cost for DIY.
    Apr 2002
    Illinois
    My opinion about the NewForm's I heard was that you had to be a good distance from them for the woofer and tweeter to integrate. Many people were modding them and claimed that the mods took care of that problem. I was about 8 feet from them when I heard them. They still sounded very good, though. I don't know about the newer models that Newform makes today.
    Using the SEAS driver, there was absolutely no integration problem. It didn't seem to matter what I did with different crossover configurations, both drivers integrated perfectly. I had also read that crossing over at 1,000Hz is problematic, but I can't hear problems.
    When it was done and over with, I paid about $25 for each SEAS driver which is about one tenth of their cost new.
    As for the cost of building your own Thor, it's very cheap for the quality you get. Speaker parts will cost about $1,500, crossover parts about $200 (guessing), and the boxes (DIY) about $200. In round numbers, about $2,000 total (for a basic box). To buy equal sonic quality from a retail store would cost about $10,000 to much more. That price is completely subjective because price doesn't always equate to quality and personal preferences don't always align themselves across the board.
    Madisound has the Thor kit for $1,771.06. The Madisound Speaker Store
    Thor reviews:
    Seas Thor review « Jane and Didier in BRUNEI Darussalam
    TRIBUTE TO SEAS THOR TL KIT - YouTube
    Still, $2,000 is a lot of money and a leap of faith to buy without hearing them first..
    Quote Originally Posted by StevenSurprenant View Post
    It's certainly true that you would pay multiples of the DIY cost for a built equivalent of the THOR. The Madisound price is for the drivers and crossover only, not the cabinet or cabinet hardware.
    The point about personal preference is well taken of course. I would rather have a Magnepan MG 1.7 for two grand than the DIY Thor, much less a Thor-based factory build for, let's say, $5000.
    Apr 2002
    Illinois
    I tried a PS Audio Power Plant which converts the AC to DC reclocks and converts the DC back to AC, but I couldn't detect any audible difference. It show about 7% AC distortion coming into my house and reduces that to .7%, so it is doing something. I have read reviews from people who have heard real improvements using this device.
    My ART phono preamp manual states that it can use 7-12V DC or 9-12V AC. Also either polarity of DC will work. That sounded odd so I wrote the company to ask them if I can use a car battery (12.6 V) with it. If it can, I'll try it out and let you know if it makes a difference.
    I took my digital completely out of the system. I can still use my surround system for that if I need it. The ART has digital circuitry, but there is nothing I can do about that.
    People with higher end turntables say it's worth the cost. I'll probably never find out, but it I will always wonder. I've read about moving coil cartridges and that's intriguing, but the cost is too high to find out. If I could find a loaner (cartridge & preamp) I wouldn't mind trying it someday.
