Results 1 to 25 of 126
Threaded View
  1. #11
    Oct 2005
    Pioneer 655 universal versus separate CD players .
    I listed the CD players that I think are good value in the low to mid price ranges in my post above :- 12-24-2005 , 12:18 AM ------------ #110 . I recommend you take your Pioneer to the shop and compare it through the same amp and speakers with some of those CD players . Use the most challanging music CDs that you have - ones that you think are critical to reproduce well . As you have written you understand about design and parts , etc ... for Receivers versus dedicated Amplifiers , apply the same thinking to Universal players versus dedicated separates . Most people trust their eyes more than their ears , and Manufacturers know this , thus for lower priced Universal players most of the design and components budget is spent on the picture quality ; next is spent on "new technology" such as any included DVD-A or SACD , and least is spent on "old technology" CD audio . Denon ; Marantz : Pioneer : Sony : Teac , and some others , can make good Universals with good CD audio if they want to , but any such will be very expensive - for both the extra parts ; design ; assembley costs , and that only a small number of these will sell , because most people do not care , or know about such as better for CD audio . seriously , Chris . .................................................. ..................... P.S. :- as well as the Marantz's and NAD CD players I have heard and recommend in #110 above , listen also to the Rotel RCD-02 . I compared it to the NAD 542 and heard both got equal detail from my CDs and both played equally well in terms of rhythm and timing , but each had a different "timbre" {presentation of tone of instruments and voices} - both were equally good , but simply "different" in that aspect . The Marantz 6000oseLE version got more detail off the CDs than the NAD and Rotel , and replayed the lowest pitched bass notes with less of their "fundamental" filtered off than occurred with the NAD and Rotel-02 . You have wide-bandwidth speakers , so you may wish to consider these aspects , so chose your test CDs carefully and compare all the CD players through the best quality amp and speakers that the shop will allow you . If you can afford one , listen also to the more expensive Rotel RCD-1072 . I have not heard it , but some Rotel enthusiasts say it is better than the RCD-02 , and it should be at its price !
