Results 1 to 25 of 33
    Suspended markw's Avatar
    If you're saying that your speakers came from the factory needing enough attention that you had to totally re-engineer the crossover, the speakers suck to begin with.
    Also, remember, it's easy to "change" the sound of something but "better" is subjective.
    I pickd up a Tivoli Isong at Sears and it's the best portable hi-fi I've ever owned. It's not where you buy something, it's what you buy.
    Philadelphia, PA
    There's not a whole lot that pixelthis and I agree on. His opinion of CV speakers is something we do agree on. They are absolutely horrid. They make me want to cut my ears off and run away. If they had used them on Noreiga he would have given up in an hour at most.
    markw is correct about re-engineering a pair of speakers. Rather than go through all that, why not buy some decent speakers in the first place? It will probably be cheaper and certainly less time consuming.
    With that said, the new CV models that were recently introduced have been getting very good press. I haven't heard them. However, people who's ears and opinions I trust have good things to say about them. They have also said that if you like the traditional CV sound you probably won't like the new ones. That in itself says a lot of good things to me.
