To simplify, if your TV does not have red/white analog audio output jacks, you ain't gonna be able to do what you want. You need a TV that has them.
Mark is 100% correct on that one.... either your tv has audio out or it doesn't.... and you need audio out to do what you want to do...
If you have it, then it should be a simple enough process.... I pretty much had the same set-up you're talking about, 6 years ago when I was a kid.... my Sharp 25 inch tv had audio out that I connected to my Technics (Panasonic) receiver....
