Results 1 to 25 of 31
Thread: Hafler help
Threaded View
  1. #18
    Quote Originally Posted by melvin walker
    Having owned a pair of Hartsfields for 41 years I think I know a little about them. I will not comment on your remarks regarding me. It is a waste of my time.
    I have owned one other JBL speaker system the JBL C 34 ,with the 001 speaker system.
    I have listened to the L100's on several occasions , I considered buying a used pair for my daughter. I choose AR2a's. There were some bad speakers built in the 60's in my opinion the JBL L100 Century's was one of those speakers.
    That is my opinion.
    Assuming that all this is true you are certainly entitled to your opinion. However, in this instance you're tendency to discuss the very narrow area of audio reproduction about which you are familiar leads the conversation off-topic. The gentleman simply wanted to know whether it was possible to connect his sub to his existing system and, presumably, specifics on how to go about doing it.
    It is possible that in a different and more appropriate post mbeigh might want to learn about the history of audio. It's also possible that he might be interested in some innovations of the last fifty years which would rule you out. In any case, in this thread the guy just wanted to get his system up and running. Was your post in any way helpful? Could he listen to music after you subjected him to your rambling and subjective "history lesson"?
    Peer long and hard through the thorazine haze, melvin. You'll see it eventually.
