Isn't there an acoustically invisible material he could use to make a wall? The speakers could just hide behind it? Is this off the wall? (no pun intended)
As mentioned earlier, it's referred to as 'scrim' in the theatrical AND upholstery trade...A very fine mesh of a fabric(sort of gauze-y, but not quite), usually black, which, under the proper lighting conditions, hides all that is behind it...You may find some fixed to the underside of your chairs and sofas where it is used as a dust-block...
jimHJJ(...there are many solutions, some simpler than others...)
