Results 1 to 9 of 9
    chicago
    Entry Level Sub -- Velodyne VX-10 or Polk PSW10?
    Hi, all!
    I'm just a newbie, dipping my toe into the pool of HT and audio.
    I've just purchased a Yamaha rxv-559 receiver and the Fluance av-htb speaker system.
    I'm considering the Velodyne vx-10 and the Polk psw10 subs.
    Any thoughts on entry-level subs in a smallish room (15' x 15')?
    Love, laugh & listen...
    Audiophile Wireworm5's Avatar
    Jan 2002
    Rupert's Land, Canada
    I don't know if the rx10 has the bypass crossover where you can use your receiver crossover. If it has great if not I'd recommend going with the CHT-10 instead which has it. This allows for a smoother integration of the sub.
    Hsu Research?
    Or, just build a Bigger-Is-Better with one of those 8" tang-band subwoofer drivers.
    Velodyne, hands down.
    Feb 2005
    Velodyne
    chicago
    thanks for the replies...I'll research the crossover settings on the velo vx-10, and consider the cht as an alternative.
    As for the DIY project, I think I need a bit more 'seasoning' before tackling that, but it's something I'll file in the back of my mind for later...
    Peace.
    SuperPoser Rock789's Avatar
    Feb 2005
    Ohio
    Titanic 10 Assembled
    Titanic 10 Kit
    Titanic 12 Assembled
    Titanic 12 Kit
    Titanic 15 Assembled
    Titanic 15 Kit
    the kits have everything in them, it's basically connect 2 wires, mount the speaker and mount the amp...
    The Titanic systems come in a kit form that can be easily assembled in approximately 1 hour. The subwoofer driver, amplifier, custom cabinet, and all necessary hardware are included, and can be assembled with just a few basic tools. The cabinet itself is ready-to-go, including driver cutouts, amplifier cutouts, pre-installed T-nuts for driver mounting, and pre-installed T-nuts for the spikes.
    HT: Anthem AVM 50 / PVA-7; Focal JM Lab 4x Chorus 716 S, CC 700 S, 2x Chorus 706S; 2x 12s - Homebuilt Sub
    2CH: B&K PT3 s2, Anthem PVA-2, VonSchweikert VR-1
    Computer: Denon AVR 2805, Old Tecnic & Optimus Speakers
    2004 KTM 200 SX
    2003 Spyder
    2002 Single Cab, 3" cornfed lift, 34"LTB & 31" AT's
    ONLINE PHOTO ALBUM
    chicago
    spasticteapot, and Rock789:
    your suggestions are very intriguing, especially when I checked the Titanic site, and read how simple the kits are.......stay 'tuned' ;-)!
    Aug 2005
    Posted in da cut
    Quote Originally Posted by dexterity
    Very easy!!! I've put together the 10" and 15". Others have put the kits together for the first time recently as well, with no problems. The 10" is going for $288 with free shipping I believe and their CS is excellent.
