Results 1 to 6 of 6
    Feb 2015
    Unhappy connection of a niles sw300 and a yamaha sw-4 subwoofers to a yamaha rx-a840 receiver
    Is it possible to connect use both sw's to my 7.2 home theatre?
    Philadelphia, PA
    A 7.2 receiver should have two LFE (low frequency effects) connectors. Connect one subwoofer to each.
    JoeE, just noticed you list Ortofon, which carts have you used? Sorry to the OP for the hijack but not much to ad to the answer you already have.
    Feb 2015
    two subwoofers connection works welland t
    Quote Originally Posted by JoeE SP9 View Post
    Connection successful. Thnx Newbie Ramee
    Feb 2015
    Goodluck Ramee
    Quote Originally Posted by ramee View Post
    One sub to the sub out on the receiver and then hook up the other subs to the speaker level outputs to the speaker level inputs of each sub.
