Results 1 to 4 of 4
    Jun 2014
    CD Player saying 'no disc" after cleaning laser.
    I've just bought a Rotel CD-991 and it frequently skipped (or at least lost sound for a moment) during playback. It did it at some point with almost every disc I tried although all discs played perfectly for 99+% of the time. Replaying a track after a skip would not produce a skip at the original skip point so I suppose the fault lay in the CD player rather than in the discs.
    Being an intrepid sort, I today took the top of the case off and-cleaned the laser lens with a camera lens-brush (no fluids) and now, whenever I insert a disc, it says 'No disc'.
    When I insert a CD, the tray closes and the disc rotates about 90 degrees clockwise, then pauses for a moment, then moves another 45 degrees clockwise.
    The display then shows the 'No disc' message.
    I've done this in a darkened room and at no stage does the laser flash.
    Woe is very much me.
    Can anyone help?
    ***** Lurker
    Newport, Rhode Island
    If you haven't called Rotel yet then that is my recommendation. Sounds like touching the lens has perhaps caused a misalignment. Best of luck!
    Oct 2005
    You may have a servo or motor issue. Whenever I put a disc in it spins so it an be read for title and other pertinent info. The fact your only rotates a partial rotation seems more of an issue than the laser.
    Sep 2014
    There are many good information and details so I hope you will read carefully and take more information by take a look here.
