The amp is still running strong and sounds great. I am going to replace the 10,000uF 40v electrolytic power supply caps with Vishay Caps or Rubycon, they cost less than $10. (By the way, is there any benefit of using a higher Voltage cap like 50v or 60V as well as 12,000uF's as there is a larger selection). I am willing to spend about $100 on the amp, maybe a little more because of the sentimental value and it has the nice 1970's vintage sound along with a decent phono preamp. I have to pop the hood and see what other caps are in there. I should be able to do the recap myself as I have decent soldering skills. There is a nice thread about replacing caps on the audiocircle forum that I found that will be helpful when choosing new caps.
Thanks for the info!
