Results 1 to 25 of 157
    I personally hope it drives Lexicon out of business and the same for any company who does this. Taking a piece and modding it to be your own offering is one thing but what Lexicon did is a crime. This type of business practice shouldn't be taken lightly by any of you. "Nail in the coffen" may be correct, people see this and it is a black eye for higher end audio. A trust has been broken. Bring on the Chinese gear. I guess it's also a real lesson for us who buy to definitely rely on ourselves as to if we hear or see any improvement. I'ts buyer beware but....... that's just extreme.
    I remember back when Yamaha making Carver's tape decks and things like that went on, and you hear that manufacturers build to the brand's specs. Even if Carver had a straight yamaha with Carver's name it isn't as extreme as what Lexicon done. A $100.00 is one thing but $3k is another. Sure manufacturer's gear may share some parts when only a number of makers are available but you don't expect the end product to be the same.
    Ajani
    It really is a disgraceful move by Lexicon.... The standard practice in High End is to upgrade to more expensive parts (even if you use the same layout)... Whether those more expensive parts makes an improvement in performance is often up to debate... But to use the exact same parts is just a straight up scam...
    If they had at least replaced all the internal wiring with Nordost Valhala (or something suitably expensive) then they would have some basis for the significant jump in price, even if Audioholics tested it and found that it gave no significant performance improvements over the standard OPPO....
