Results 1 to 25 of 136
Like Tree51Likes
    Jul 2002
    Not to be rude, but why don't they seek out visually impaired people for auditory challenges? (very PC)
    Reading the article goes a long way!
    There, the researchers suggested preventing sight for as little as a week may be enough to help the brain process sound more effectively.
    This was in the article.
    They didn't mention the blind because they already did a study on that as well.
    Short stays in darkness can boost hearing, study shows - Medical News Today
    Reading the entire article helps.......
    Sir Terrence
    Oppo BDP-103D
    9 Onkyo M-5099 power amp
    9 Onkyo M-510 power amp
    9 Onkyo M-508 power amp
    6 custom CAL amps for subs
    THX Style Baffle wall
    3db
    3db is offline
    Jan 1970
    This article presents a solid reason why I think blind listening tests are more accurate than sited listening tests with respect to electronics.
    Just not the overwhelmingly common bogus type which use switchboxes that combine signal grounds, use extra cabling and other uncontrolled devices and assumptions that are not normally present.
    People who are blind from birth have extraordinary hearing most times. That is why Double Blind Testing would be better done with Blind people. Nobody can be accurate by being blindfolded for a short time as opposed to normal hearing for life of a blind person because they are not used to it and each time blindfolded the hearing sense change can be a little different.
    If they did cable swapping tests with blind for life testers, and they did not hear any changes ever, I may change my mind.
    3db
    3db is offline
    Jan 1970
    Blind in this case simply means not being able to see the equipment used prior to and during the test. It doesn't mean blindfolded.
    When the term is "double blind", you are mistaken. That means that both the person taking test AND the tester do not know which is which. As for me, I don't have a problem with single blind studies. The "Clever Hans" cueing effect can be eliminated.
    Randomizing digital content using the same player works fine. Running gear through extraneous boxes or Y-adapters merely blends electrical characteristics of the devices under test.
    3db
    3db is offline
    Jan 1970
    I never mentioned DBT in this thread.
    Jul 2002
    Now they(and I) use computers to do the switching. At AES they use computer controlled ABX testing. Since nobody but the computer is switching, the Clever Hans effect is eliminated.
    If you are DBT wires and IC, those are directly interfaced with the multiplexer - and the computer can choose between which input to listen to, single blindly or DB.
    I am not sure they make those old standalone ABX comparator boxes anymore. Too many people like me could hear the thing switching, and therefore cheat the system.
    Sir Terrence
    Oppo BDP-103D
    I know, all I was implying is that Blind people have way better hearing than you and I whether we can't see the cable, are blindfolded or in a dark room.
    Jul 2002
    Sorry, but not all blind people have way better hearing than sighted people. Some maybe, but not all.
    Sir Terrence
    Oppo BDP-103D
