Results 1 to 25 of 97
    I will choreograph the poses after I get my snacks. Uh what direction is the lobby?
    Follow the pink & purple lights along the floor.
    Lower AL
    Walks in late as usual, but nonetheless holdin'. Calmy takes a seat on the rug carefully avoiding the puke, finds the 30 year old copy of DSOM under the couch, sets it in his lap, pulls something from his pocket and rolls one that looks like a VW Beetle. Everyone begins to perk up.
    OK so my thinking was a little off last night I have after all been on binge of sobriety for weeks. My mind has been tweeking thus the result you saw last night.
    Enters the room your all in and Yells (AYY I NEEDS A FRIGGEN HIT!!) with my best Ewan Mecgreggor impresion from trainspotting
    OK so my example of how to conduct an experiment wouldn't work but I know there has to be way to scientifically come up with an answer some other way.
    Other myths rathar missconceptions about subwoofers could be addresses.
    such as:
    10"s hit harder and are better for rock and 15"s can't hit as hard because they move slow and thus are only for rap music because they sound deeper.
    Just about everyone I know that thinks they know about car stereo say this dealers say it also. Do your homework and dig deep enough you'll find that a 15" can hit just as hard as a 10". The 10" lacks low extension so it appears as if it has more punch because you cant hear the lows you should be hearing that the 15 will reach. So sence because they hear the lower sounds from a 15" they think it's slower and all together lower sounding. There half right it does sound deeper but it's also hitting all the higher hz that the 10 is except for just a few hz at the wery top that usually crosses over to the midrange speakers.
    I know theres a ton of lies and misconceptions out there that could be proven otherwise through some sort or scientific method.
    Quote Originally Posted by Mark_IDT
    such as:
    Woofer size has nothing to do with woofer speed - compliance and excursion will affect the woofers transient response or speed and the tightness or slam.
    15" woofers are actually better at this. It's swept volume of air you need to consider. A 15" woofer moves about 6 times the air of a 10" sub. That means a 10" sub has to move 6 times as forcefully to match the output of the larger sub - since 15" magnets and motors are usually bigger, they are also more powerful,...so the 10" woofer then relies on its excursion to push air - the further it moves, the less control it will have, transient response suffers.
    I think with car subs especially, the issue was there's just a lot of crappy, power sucking, hi-excursion subs that sound bad. In a cabin the subs benefit from transfer function (cabin gain) and you can get away with 10 and 12" woofers. - 15" are usually overkill and just for competitions...
    Dec 2004
    Santa Rosa, CA
    Walks in room, notices nice collection of local color, asks first awake person, "Why are we here?"
    There's no answer.
    Hayes, Va
    ahhhh just like the ole days...
    beers....smokes....and insane conversations...
    I miss you guys....
    Peace, Pogue
    • Mark Levinson No. 27
    • Musical Fidelity 308cr
    • Martin Logan Prodigy's
    • Ariel Acoustics 10-T
    • Rega Planet CD
    • CJ Premier 9 DAC
    • Benz Micro Cart.
    • Akai GX 747 Reel to Reel
