Results 1 to 17 of 17
    Jun 2007
    Sony Reciever + Crown Amp...will it work
    I was thinkin about getting this Sony Reciever:
    http://www.bestbuy.com/site/olspage....=1076628923551
    And pairing it with this amp:
    http://www.musiciansfriend.com/produ...ier?sku=481584
    But i don't know how to wire the amp. Does anyone know if this will even work. I just want something loudd.
    Thanks in advanced!
    May 2006
    San Francisco Ca
    First, Welcome to AR. Your receiver choice is sound, and Yes, the combo will work,
    However, There are simpler (And cheaper) ways to go. Using a Pro Amp at home has
    special considerations, In the ad, you see XLR inputs. Well pre-amps for home use
    have RCA plugs. The amp has Balanced inputs, Your Receiver pre-amp is unbalanced.
    You can buy an interconnect that is rca on one end to xlr on the other, to make the
    connection. Pro amps are noisy due to there fans, also there can be hum issues. There
    are ways around that. On the plus side, Pro amps supply huge amounts of power for
    hundreds (even thousands) less than a high end "Home power amp", They run forever,
    As there meant to be abused on the road. There are alot of used home audio 200wpc Amps
    out there, that will be pretty much, Plug and play, But if you want to do it, Go for
    it. Good luck
    Sunfire TGP-5 Pre/Pro
    Carver A760-x
    Carver TFM25
    Carver TFM15 x 2
    Sunfire Signature "True Sub"
    JBL Studio L890(Front)
    JBL Studio L830(Rear)
    Infinity PC350(Center)
    Oppo Digital 983H
    Panasonic Viera TH-46PZ85U
    Panasonic DMP-BD50 Blu-ray Player
    Power Protection/Filters-Monster HTS 5100 MKII
    Canare Interconnects
    Forum Regular Blue Meanie's Avatar
    Wisconsin
    Quote Originally Posted by Jirobinson13
    Thanks in advanced!
    That receiver has no pre-outs. How you gonna hook up an external amp (the Crown) to it? I think you're SOL.
    Jeff
    P.S. Welcome to the 'group'!!
    PIONEER: SX-780, CT-F700, HPM-100(x4), DV-C302D, PD-F1007, PL-514; DENON: AVR-983; SONY: D-15, DVP-985V, DVP-CX860(x2); TOSHIBA: XR-9459; TECHNICS: SL-1800MK2, SL-1700MK2, SL-1400MK2; NAD: PE2200; PARADIGM REFERENCE: STUDIO 100 V.2, SERVO-15, X-30; CERWIN-VEGA: DX-9; REALISTIC: MACH 2; RCA: 42" LCD HDTV
    Mutant from table 9
    Mar 2005
    Blue Meanie is right, this combo won't work at all. If you want loud, that depends more on the speakers than it does the amp. What speakers are you using?
    ______________________
    Wisconsin
    Well actually, it CAN be done, with one of these:
    http://www.partsexpress.com/pe/showd...number=269-050
    But I don't know if it has a detrimental effect on sound quality or not. Although in this case, that might not be a concern.
    They are used in car audio all the time.
    Yeah, more efficient speakers (like Cerwin-Vegas, for example) would probably be the easiest way to get LOUD.
    Jeff
    Jun 2007
    Quote Originally Posted by Blue Meanie
    Jeff
    I found a Cerwin-Vegas but it was $750 for a the sub woofer. Where and how much do those babies cost. I don't mind the sound quality being perfect but I don't want it to sound like a old radio. I'm planning on running my laptop to it which uses a 3.5mm jack but can easily be converted to RCA or 1/4 jack.
    Thanks
    Wisconsin
    Thanks
    Well, I don't know JACK about new(er) Cerwin-Vega speakers. But the older ones (such as my DX9s) are known more for their efficiency/loudness, than sound quality. They aren't a BAD speaker, but they are meant more for partying/loud rock, as opposed to hyper-critical serious listening sessions. Pairs of older C-Vs can be found on ebay for anywhere between 50 bucks a pair, to a couple hundred a pair, depending on size and popularity. If you want something relatively large (15" three-ways), the D-9s, or AT-15s would be a good choice. Shipping these can be a real bear though, and costly, due to size and weight. You might be better off searching your local Craigslist (if you have one), to avoid shipping costs/hassles. Older models by Klipsch would also be a good choice, but probably a bit pricier than most C-Vs.
    You can get much more bang for the buck by going the used route instead of new.
    Jeff
    Jun 2007
    Thanks for the welcoming, I couldn't find a single good audio forum to ask this question! I guess i found it. Oh, I was thinking of getting 2 of these:
    http://www.musiciansfriend.com/produ...ker?sku=600735
    I am going to be taking it places but it wont get very abused. What would you guys recommend? Keep in mind my budget is around $500-$1000.
    Thanks.
    Suspended markw's Avatar
    Check the used market.
    Look for a NAD 1600/1700 tuner/preamp or an Adcom 400 - 400 series tuner/preamp. You may pay a few pennies more but youll get much better quality.
    http://cgi.ebay.com/ADCOM-GTP-500-Tu...QQcmdZViewItem
    This guy's a bit on the high side. I paid less for my 1600 nine years ago. They should be in the $125 -$150 range nowadays
    http://cgi.ebay.com/NAD-1600-Preamp-...QQcmdZViewItem
    Jun 2007
    Yeah see, i'm a newbie, i don't even know what a pre-out is. I'm just getting into the whole amplifier thing, i've always used receivers and just some crap ass speakers lying around to crank music and its always gotten loud enough but now i got bigger space and I might bring it to party so id like it to be louder. If you guys just want to give me a system you would do for $500-$1000 that'd be awesome. Thank you guys so much i'm glad i asked before i bought this stuff.
    Wisconsin
    I agree with markw in suggesting NAD or Adcom components. I have had great luck with NAD stuff personally, but there are some folks have had problems with specific models. I've never owned any Adcom stuff, but have 3 or 4 friends that have had fantastic luck with their Adcom stuff, and it seems pretty much bullet-proof. Both NAD and Adcom offer good sound quality at an affordable price.
    If you are looking for a relatively 'portable' system to transport to parties, my suggestion of C-V D-9s or AT-15s may not fit the bill. I'm only guessing, but those speakers weigh in at about 70 pounds (each) or so. But C-V made smaller models in the 'D' and 'AT' lines, sacrificing a little bass, but still being extremely efficient and capable of being played loud.
    Jeff
    Forum Regular DEVO's Avatar
    Florida
    Here is an example!
    Look for a good receiver (2 channel) w/ POWER, here is an example.
    http://www.yamaha.com/yec/products/p...ETYP=ATTRIBUTE
    And here are some speakers!
    http://www.jbl.com/home/products/pro...at=BFS&ser=CNS
    This system should ROCK!
    If you need more POWER, receiver has pre-outs to add amp. But it should maintain enough current and JBL is efficient and know to be a DANCE CLUB speaker!
    Let us know how it goes!!!
    Jul 2006
    you know, he plans to get the behringer ACTIVE speakers, no need for a seperate amp, just a preamp/mixer (for the PA dudes)
    but I seriously recommend you to listen to some speakers first, before you buy, you know, 'loud' is just loud, it's the 'good' part that bothers people.
    and btw, please don't buy the cheap sony thing...
    if you want loud speakers, buy a pair of cerwin vegas. you do need a receiver/integrated/seperates here, but those are no problem.
    Life is music!
    Mcintosh MA6400 Integrated
    Double Advent speakers
    Thiel CS2.3's
    *DIY Lenco L75 TT
    * SME 3012 S2
    * Rega RB-301
    *Denon DL-103 in midas body
    *Denon DL-304
    *Lehmann audio black cube SE
    Marantz CD5001 OSE
    MIT AVt 2 IC's
    Sonic link Black earth IC's
    Siltech MXT New york IC's
    Kimber 4VS speakercable
    Furutech powercord and plugs.
    I'm a happy 20 year old...
    your main concewrn is loud and portable?
    Check out the top of this page. Just plug in a source. Heck, even Ipod/MP3 players works fine
    http://www.musiciansfriend.com/home/...s&r=&src=00632
    We use 'em at the church and swear by them, figuratively speaking that is.
    Jun 2007
    Ok guys so I bought some Logitech Z-2300's (i got them for $50)
    http://www.newegg.com/Product/Produc...82E16836121122
    Blew the speakers within 5 minutes. The sub woofer is awesome though, I bought some Insignia speakers for them at Bestbuy for $20 http://www.bestbuy.com/site/olspage....=1118843685964
    Its amazingly loud and awesome for the price, but i'm looking at getting a way better system. I was looking at getting some JBL or C-V speakers on ebay. For the receiver/amp im not sure what to do yet. I'll probably get a powerful receiver and eventually hook a amp to it. Honestly though if you guys need something to throw around like crazy that Logitech/Insigna hookup is amazing for the money, I use it for video games and music, and when you pump it walls shake.
    Mutant from table 9
    Mar 2005
    Romanticist Philosopher
    Aug 2001
    Long Island NY
    Smile Here are some other suggestions
    Thanks in advanced!
    I'm assuming that 2 channel audio is your concern so I recommend this Insignia reciever from Bestbuy.
    http://www.bestbuy.com/site/olspage....=1169512582154
    It has 2 stereo pre-outs so you can run that to your amp. You will still need the Radioshack adaptor for RCA to 1/4" to run signal to your amp. The reciever is currently backordered but be patient.
    I love the Behringer EP 2500. Check it out here.
    http://www.amazon.com/BEHRINGER-EP25...2208821&sr=8-7
    I have 8 of them and other than the fan noise it is just fine for everything I use them for whether it be movies, music, or video games in a 7.1 setup with lots of speakers. For about $300 it can't be beat.
