Quote Originally Posted by N. Abstentia
Yeah good advice so far. Like Worm said if you don't want to put them directly on the walls then get some thin wood and cut out backings for them then hang them just like a painting. I was going to do this myself but went the 'stuck right to the wall' route in the end because I won't be moving anything (when your screen is painted on the wall it's kinda permanent!).
Don't forget about the back wall also, although it should really be diffused and not absorbed so don't go overboard on the back. You don't want it TOO dead.
Good point there...maybe a center channel reflection spot. For diffusing (is that even a word) the sound, I know Auralex sells those diffuser panels as well, but would there be any benefit to using the normal wedge tiles? Maybe spaced apart or something? I've got enough of this stuff as is, I'd hate to buy more.
BTW, your HT room looks wicked! I gotta get myself a new digital camera (last one fell into the Atlantic Ocean somewhere off the coast of Maine when I was chasing a whale. What's up with the Palm trees?
