Results 1 to 25 of 26
    VB VA
    Quote Originally Posted by cyto
    Keeping in mind that price is a major issue, I found a Marantz PMD 320 on CL for $59. Would I be better off with a new budget blu-ray player or the Marantz PMD-320?
    I am not in the camp that a DVD player can not make a good CD player as I use a Oppo DV-970HD as the SACD/CD player in one of my 2-channel set-ups. Having said that just because the Blu-Ray is newer than the Marantz it does not automatically mean better sound. I think you need to research the exact Blu-Ray players you are looking at for your budget and then if possible give them an audition to see if you like them. The Marantz appears to be a solid player but you always have to be wary of how much laser life is left on an older CD. I have purchased several quality stand alone CD players for less than $59 but I have been a bit lucky in that area. If you can get the seller down some on the Marantz and none of the Blu-Ray players sound good to you then I think you have your answer.
    NAD D3020
    Denon 2910
    Denon DMD 1000
    MSB Link DAC III
    Von Schweikert VR2
    NAD 7240PE
    NAD 5240
    Hughes AK 100
    Tascam 122
    Technics SL 1700
    Rogers BBC Monitors LS3/6
