Results 1 to 25 of 123
Like Tree13Likes
Thread: Using Cables as Tone Controls
    If a IC is brightening or darkening the sound, it is defective PERIOD. An IC job is to transport a signal from one component to another - adding little to nothing of a sonic signature to the process as possible.
    The exception would be cables that include a Zobel filter network. I believe examples includes made by MIT, Transparent, and Siltech. These are designed to modify the signal, and it shouldn't surprise that they will sound different from "straight wire".
    Jul 2002
    Actually those cables are not made to transparently transfer a signal from one component to another. They were made to sonically change the sound, and claim it is better than straight wire. Vinyl records are essentially the same in that regard.
    Sir Terrence
    Oppo BDP-103D
    9 Onkyo M-5099 power amp
    9 Onkyo M-510 power amp
    9 Onkyo M-508 power amp
    6 custom CAL amps for subs
    THX Style Baffle wall
    Actually those cables {MIT, Transparent, and Siltech} are not made to transparently transfer a signal from one component to another. They were made to sonically change the sound, and claim it is better than straight wire. Vinyl records are essentially the same in that regard.
    At least these cable makers are forthright that their designs modify the signal although of course they all insist it's for the better.
    It's been perfectly clear to me for long time that vinyl's virtue is to filter the sound in a pleasant manner. It's true, OTOH, that a well-mastered and pressed LP will sound better than a poorly mastered CD. I haven't bought an LP in almost 20 years but that's propably because there is virtually no selection on the medium for the classical music I mostly listen to.
    I suspect it's the same sort euphonic preference that sustains the popularity of tube equipment.
    Jul 2002
    The funny thing is, almost all cable makers say their design makes the audio better. And when they suggest this to the public, some gullible people will actually believe them. We have seen examples of this right here.
    A simple null test can tell you if there is any audible differences between IC. Simply put signal in opposite polarity going through each cable. If there is sound coming out, the cables are audibly different and measurements will tell where. If there is no sound at all, then there is no difference between the cables. I have done this test a least two dozen times. The only time I heard a difference between two IC was when one was WAY longer than the other. Signal losses based on distance is a well known phenom.
    Sir Terrence
    Oppo BDP-103D
