Quote Originally Posted by A-Audiophile
Power cables DO make a difference.....but it all depends on whether or not the equiptment is sensative enough to a different power cord to make the difference audible. Putting premium gas in a non proformance car will make no difference either....same difference.
Let me see, the electric power you receive in your home has been generated many miles away. It is transmitted via copper cables for that distance which can be quite significant. It then reaches your home and traveles throughout your entire home on copper cables. After all this copper electrical transmission you are telling us that the last foot of cable makes any difference whatsoever. Amazing.
By the way, you don't happen to be shilling for a high end powercord company are you?
