Results 1 to 4 of 4
    abNORMal IBSTORMIN's Avatar
    Blue Springs, MO
    Power cord length
    I wonder as I finish an area of my basement for my audio equipment if the wires in the wall generate a magnetic field that can interfere with the equipment. Which has more advantage for my money: the plug directly behind the equipment with a short (higher quality for the same money)power cord or off set the plug to one side away from the components with a longer (lesser quality for the same money) power cord??
    May 2009
    Helotes,TX
    While checking out old reviews on Stereo Times website, I happened across a review for Loss Less Dynamic Filtering power cables. Check out their presentation/explanation for their design.
    DFPC Series cables : High end power cables | Audiophile power cords | Audio power cables by LessLoss
    My audio lab:
    Qinpu A-6000 MK ll Integrated Amp
    Blue Marble Audio Speaker Wire
    Tannoy Mercury V4
    HHB CDR-850
    Grant Fidelity DAC-11/Phillips 7DJ8 tube
    Parasound Zamp V.3/Parasound ZPre2 Preamp
    Signal Cable Analog 2 Speaker Wire
    Dali Ikon 2 mk 2
    Marantz SACD/DVD DV6001
    Stello DA 100 Signature DAC
    HT:
    Arcam AVR 200
    Signal Cable Classic Speaker Cable
    Mirage Nanosat
    Rel R-528 Subwoofer
    Various power cords, I.C.'s, optical, coax, and analog cables.
    Blue Springs, MO
    Makes sense for their cables
    Quote Originally Posted by LeRoy View Post
    Interesting cable. Because their cables skin is a filter, it makes sense that the longer they are, the more filter you have.
    Blue Springs, MO
    I guess my question really becomes: does an AC wire in the wall generate a magnetic field or does the pulsing of the two wires negate themselves as they are going in opposite directions?
