Results 1 to 25 of 92
Threaded View
  1. #11
    fergot... whasa XLR3?
    Studio City, CA
    As far as I know, most errors in FO transmission occur at the ends, unless there is some damage somewhere along the medium, and those can be located with tdr. When i find one that's acting up I just get another. When we do long runs we install many extras just for this purpose, so we aren't trying to polish an end there in the field, in a big hurry.
    I suppose glass might be more optically pure than plastic. I'm pretty sure i remember there are also wavelength capability differences, but if a system is designed properly then I doubt if it would matter. Most likely the ends are the biggest difference between a cable that sounds good and one that doesn't.
  1. Onkyo TX-SR600 optical connection question. Please help.
    By Haphazard in forum General Audio
    Last Post: 03-15-2005, 11:15 PM
  2. Another coax cable question re. DVD audio
    By tcontas in forum Cables
    Last Post: 03-11-2005, 04:00 PM
  3. Need 20 ft long cable -- will optical work?
    By douglasbjordan in forum Cables
    Last Post: 06-27-2004, 09:15 PM
  4. cable brand question
    By mjnoles1 in forum Cables
    Last Post: 06-08-2004, 01:44 AM
