The problem I have with just about any discussion of cables is that both sides of the argument are generally not based on proper application of science...
For example, I might not be able to tell the difference between 2 wines under DBT..
You've identified a third non-scientific approach: the use of unsupported assumptions concerning the very test procedure used to "prove" the question. First of all, do you ever switch interconnects between say a source and pre or power amp while both are powered up and set to normal listening gain levels? Of course not! Why? Well, the noise or huge POP! can potentially damage downstream gear or at least open a fuse. Performing a double blind test of cabling necessarily requires connecting both cables to a switch box between the components used. Naturally, the use of external uncontrolled variables is not required for comparing wines! The non-experiential theorists reason that since the switch contact impedance, inductance and capacitance is low, they assume that the box does not influence the test. Such incomplete thinking completely misses the point! Preventing the POP! requires the use of common grounds. So, now you are comparing the combined electrical characteristics of both cables. Or feedback loops between two amplifier so wired.
Is it any wonder then that listeners are unable to hear the difference between using both cables and - both cables? Frank Van Alstine made that observation long ago. Some folks attempt to defend their position cloaked in the mantle of engineering using fallacious assumptions like this.
