Results 1 to 8 of 8
    Nobody Special LeoFenderBender's Avatar
    Sep 2005
    West Linn, Oregon
    Help with Speaker Cables [or adapters] for JL Audio Fathom subs?
    I have Tara Labs speaker cables [banana to banana]; I was hoping to go into dual JL Audio F110 subs but the subs only have inputs for TRS, RCA, and XLR.
    Is there an adapter that will convert a banana plug into a male TRS, RCA, or XLR?
    If not, what speaker cables should I be looking for? I'm not opposed to buying what I need. My amps are Cary Audio Design 500 monoblocks with WRS terminals that work well with bananas. I either need an adapter or new cables to run my subs.
    Any help is much appreciated!
    Cary Audio Designs SLP-05 Preamp [Sylvania 6SN7GTB]
    Cary Audio Designs CAD 500 Monoblocks
    Cary Audio Designs 303/300 HDCD [Mullard 12AU7s]
    Rotel RCD-1072 HDCD
    Luxman T117 Tuner
    Magnepan 3.6Rs
    JL Audio Fathom F110 subs
    What you need to do is get some RCA cables and go from your preamp output into the sub's RCA input. Some preamps have two outputs but if yours does not you may have to use a Y adaptor at the preamp with one side of the Y to the power amp and the other side to the sub.
    Your power amp is a high level output but the inputs you mentioned on your sub are low level inputs like from a preamp. I'm assuming from what you said the subs already have a built in amp so do not need power from the monoblocks.
    Sep 2005
    West Linn, Oregon
    Peabody,
    Excellent response. My pre is a Krell KCR3 - I am running the XLR outputs into my monoblocks leaving the unbalanced RCA outputs unused. If I understand you correctly, you are suggesting I go direct from the pre into the subs. I hadn't even considered that solution.
    The thought of melting RCA plugs from the monoblocks did occur to me...
    Thanks!
    Rotel RCD-1072 HDCD
    Luxman T117 Tuner
    Magnepan 3.6Rs
    Swing rakeford's Avatar
    Dec 2009
    First determine whether your sub has its own power amp inside the sub box. If so then go directly from your preamp RCA outputs to the RCA inputs of the sub using a standard RCA phono cable, if it's long enough. If you need more length, you can get a long RCA phono cable made specifically for subwoofers. You can also use the ” TRS or XLR if that's convenient.
    The preamp output is low power, so no need to worry about melting cables or plugs. The power is generated from the power amp inside the sub.
    The RCA input on your sub is likely a line level input to a power amp in the sub box.
    Philips GA312/ Stanton 681EEE/ Jico D6800EEE-S Shibata ===>>|
    Yamaha DVD-S2700 CD/SACD/DVD >> MONSTER STANDARD THX i100 >>|
    Yamaha CDC-765 CD 5 disc >>==== MONSTER STANDARD THX i100 >>|
    JVC TD-W709 Cassette >>======== MONSTER STANDARD THX i100 >>|
    Yamaha RX-797 Receiver -------------------------------------+
    Sennheiser HD650 Head phones <<===========================<<|
    Klipsch RF-7 <<L############### MONSTER MSERIES MCX-2S ##L<<|
    Klipsch RF-7 <<R############### MONSTER MSERIES MCX-2S ##R<<|
    Sep 2005
    West Linn, Oregon
    JL Audio doesn't make passive subs for home use.
    Rotel RCD-1072 HDCD
    Luxman T117 Tuner
    Magnepan 3.6Rs
    Krell & Cary is an interesting combo, thinking each has a different sonic character, how's it working out? Are the monoblocks solid state? Curious what main speakers you are using?
    Sep 2005
    West Linn, Oregon
    My speakers are Magnepan 3.6Rs; I have been hooked on planars for decades.
    Cary CAD 500 MBs are 500 watt AB solidstate monoblocks; to my ear, the Krell pre matches fine. The Krell pre is clean with a black background. Even with maggies, the MBs have power to spare and quickly fill the bass without smearing.
    The JL Audio Fathom F110 subs are FAST enough to keep up with the maggies, they are the fastest and most musical subs I have ever heard - easy to integrate - designed to quickly move air, the pistons are enormous.
    Rotel RCD-1072 HDCD
    Luxman T117 Tuner
    Magnepan 3.6Rs
    I have had some Krell and still have a kav-500i tucked away. I lean toward the older Krell just for the darker background you mentioned. You have a nice set up.
