HELP! Drywaller killed my cable!
I am finishing my basement, and have strung all the wires, and installed boxes for the speaker wire. When the drywaller was cutting out the box his dremel blade also cut through my LFE wire that I had run. I have 2 options . I stripped the cable to see what is in the wire. It has a silver wire, and a red and white wire. If I patch this cable back together will I forever have poor sound out of my sub? Fortunatly, I ran this setup on both sides of the room so in the future I can (could) move the sub if needed. It is not feasable to take down the hung and finished drywall at this point. Should I just forget the broken hookup and use the other side of the room, or give a patch a try?
