Results 1 to 13 of 13
    Forum Regular DanGinCT's Avatar
    CT
    Question coaxial digital vs optical digital audio cables
    Hi All,
    I need to buy a digital audio cable to hook up my Pioneer DV-588 DVD player to a new Pioneer VSX 1015 I just bought. The DVD player is mainly used for movies. I was wondering which is the best performing digital audio cable to use, coax or optical? Is there much difference? Thanks!
    Dan
    Forum Regular KaiWinters's Avatar
    Oct 2003
    Northern NY
    No difference.
    Use the search mode to find this question asked and answered.
    I use both, digital coax for dvd and optical for cable box...no discernable difference to my ears.
    TV: LG 50PC3D plasma tv
    Receiver: Yamaha RX-V659
    DVD: Philips DVP5960
    Speakers: front/Paradigm Monitor 3 v.4, surround/Paradigm Atoms v.4, center/Paradigm CC290 v.5, sub/Paradigm PDR-12
    Remote: Harmony 659
    Suspended superpanavision70mm's Avatar
    Jan 2006
    Pittsburgh, PA
    It's hard to say if there is or isn't a difference because when you are comparing the two...there can be differences is the brand and the cost involved. One thing that convinces people to go with Optical is that lack of interference that typically can appear through the Coaxial. It also seems that the Optical responds a bit faster, but often does not have some of the warmth as the coaxial. Once again keep in mind it depends on the manufacturer and cost involved. I have compared several brands over the past few years....Monster to Tributaries to AudioQuest to Tara Labs to Cobalt to BetterCables. I ended up sticking with the Tributaries Optical and Coaxial. I have them hooked up for both SACD and DVD sound.
    Quote Originally Posted by superpanavision70mm
    That's impossible. SACD signals cannot be passed through a digital output.
    Jan 2006
    Pittsburgh, PA
    I meant to say that I have them hooked up to SACD player and DVD player. Of course they do not play the SACD sound the analog cables do, but I use the SACD player to play CD's. Thanks for the catch!
    dts geek swwdts's Avatar
    KY
    I use an AR optical cord w/ my pioneer dvd.
    Dec 2004
    Cal
    So why do you player your cds with your analogs? Player is that much better then your receiver.
    Look & Listen
    Forum Regular RH Customs's Avatar
    May 2006
    Spring, TX
    I my opinion if you are just going to use the DVD player to play movies and not audio, then optical is better. I have found that Coaxial gives a more natural analog sound and as. superpanavision70mm, a more natural sound and warmth.
    RH
    Suspended markw's Avatar
    Quote Originally Posted by RH Customs
    RH
    wrong. bits is bits
    Utmostjamin1
    May 2003
    NW Ohio
    bits may be bits but my ears tell me the coax sounds better.. I use analog for sacd and i use coax for digital for dvd and cd playback. I had the optical.. I got the coax for free and it just sounds warmer less mechanical. but if you find that the optical sound better to your ears go for it.. its your ears that matter not ours.
    Dec 2004
    Cal
    If you didnt use analogs for SACD,what would you use?
    Look & Listen
    Sound Fanatic
    Feb 2006
    Quote Originally Posted by jamison
    Well your brain is causing your ears to lie. The exact, precise, completely the same 1's and 0's are passed either way. There is no processing done prior to the signal being in your receiver's DAC that would add or rob warmth. What exactly is a "warm" 1 or a "cold" 0 ???
    What you're hearing is nothing more than a creation of your mind. Do a digital capture of the same song over both cables and compare them (yes, i have)... they're bit-for-bit identical. You want to believe that one is better then that's what you'll hear. Don't pass it off as truth in here though.
    Jan 2006
    Pittsburgh, PA
    The one thing that I do not like about the Optical cables is they are flimsy and they don't lock in as well as one might hope. I am always afraid of breaking the cable. However, I have heard that the optical does not allow for as much interference as the Coax. I have both hooked up just incase.
