can i convert stereo rca to Cal Audio DAC?
Hi, I have a cd transport that has passed on and probably won't replace it as i've digitized all my music in lossless and it's easier to access. However it leaves me with a perfectly good Cal Audio Alpha DAC that created beautiful sound. Is there a sane way for me to convert stereo rca input into any of the DAC's: Coax 75; Balanced 110; Optic; and At&t digital inputs?
I'd love to feed my Mac or my iphone to it if possible. Google hasn't helped. I'd love some learned feedback on this. Thanks in advance.
Think about what you're asking.
Originally Posted by etl
...i'd like to be able to convert a L/R stereo rca cable into those DAC feeds. because, i can get to L/R rca from Mini output [airport wireless and iphone] and wireless to the audio system isn't stable enough for me to rely on it for enjoyable playback.
That "L/R stereo RCA cable" is an analog signalthat already has beed converted, via another DAC (Digital to (Analog (Converter).
To do what you want, you would have to RE-convert it into the digital domain via an Analog to Digital Converter. And then you could use your other DAC to RE-RE-convert it into analog. Is that what you really want?
To make any sense of your scheme you would need to send a digital signal directly from the source to your beloved DAC, ergo the USB or digital coax suggestions.
Gonna take more than a simple cable...
And is there a way to convert usb to any of: Coax 75; Balanced 110; Optic; and At&t digital inputs, with a simple cable that isn't some sort of pre-amp type of box?
As was previously stated:
Originally Posted by harley .guy07
Blue Circle makes a unit that will take a usb signal and convert it to coax for a dac. There are others as well but they do not come to mind right now but if they come to mind I will post.
