Results 1 to 25 of 68
Threaded View
  1. #23
    Forum Regular Rockwell's Avatar
    Quote Originally Posted by pctower
    And you must be arrogant. And no doubt you will be more than happy to impart the knowledge I so sorely lack on how to interpret my perceptions.
    I was not suggesting that I have all the answers or would interpret your perceptions(though I can give it a shot ). I was suggesting that the more technical information that you(or anyone) have about the phenomena you are trying to listen for, the better you can interpret your own perceptions. Taking you, for example, you've been here for a while and know all the objectivist aguments, yet you still believe in cable sonics. Fine, but if you didn't have the benefit of that information, you would be making a less informed choice. Knowing that a power cable, from a technical perspective, is highly unlikely to produce any audible change in a system might lead you to believe that a perception might be unreliable and persue a more friutful upgrade.
    "You two are a regular ol' Three Musketeers."
  1. Cable geometry vs. Cable size - help?
    By mcc in forum Cables
    Last Post: 01-12-2004, 02:34 PM
  2. expensive cables
    By sofsoldier in forum Cables
    Last Post: 12-22-2003, 07:15 AM
  3. Bulk cable source & suggestions?
    By piece-it pete in forum Cables
    Last Post: 12-06-2003, 08:02 AM
  4. Sub-woofer cable suggestions?
    By kexodusc in forum Cables
    Last Post: 11-29-2003, 10:14 PM
