Results 1 to 4 of 4
Thread: Valve amp kits
    Sep 2005
    Valve amp kits
    First post here so firstly hi to everyone!!!
    I wondered if anyone had experience of building a valve amp from a kit? If so was it worth while? Was it difficult?
    Ta
    Ssushi
    Sep 2005
    Just an additional thing... I'll be driving Heybrook HB4 speakers (currently with a NAD 770 AV receiver), what so of power from aan amp would be advisable?
    Thanks again
    Ssushi
    May 2003
    NY
    Quote Originally Posted by Ssushi
    Ta
    Ssushi
    Hi Sushi, I don't know of anyone on this forum that builds amps. You might want to try the Bottlehead forum on Audioasylum;
    http://www.audioasylum.com/forums/bottlehead/bbs.html
    Good luck!
    Audio;
    Ming Da MC34-AB 75wpc
    PS Audio 4.5 preamp,
    Audio Enthusiast
    May 2003
    Duarte, California
    If you can build an electronics kit, you can build a bottlehead.
    I'm not familiar with Heybrrok speakers so I don't know if the kits would work well with them. Most 2A3 or 300B based tube amps are easily accomplished if you have the patience to read instructions and can put together a simple electronics kit. I've built two of the Bottlehead kits and I am pleased with their results. Bottlehead has a surprisingly deep knowleadgebase and a large community of active people who can assist you with your questions and problems. (Even at 2:00am in the morning!)
    I've never built the Bottlehead amps because they do not produce the amperage necessary to drive my ineffecient speakers of choice. However, with a good efficient speaker set, they will produce some pleasing sound. (92+db efficiency)
