Very cool, Poppa,
Like you, I have used Lathe machine to make a LP weight, and CNC for the periphery ring.
One of the thing I had failed to recognize is that I used steel, and had forgotten the material is magnetic..... I now use both to flatten LP when needed. Works pretty well!
What material did you use?
JRA
Stainless steel. I considered brass. I wanted a dense material so i could make it small. It's doing everything it should. I much prefer it to the clamp.
