Results 1 to 25 of 176
    Dec 2004
    Santa Rosa, CA
    The woofer cone is much smaller than the wavelength being produced (100 Hz is 11 feet ) so the coupling efficiency to the air is very poor. Bass drivers overcome this problem by having larger excursions. You can't see a tweeter move (max excursion of 1mm or 2mm) but a woofer can easily be seen to move for loud low frequency notes (max excursion of 10mm or 20mm typical). So the woofer moves a larger cross section a greater distance or simply put, a lot more air, this takes more power.
    Herman;
    My stuff:
    Mark Levinson No.360S D to A
    Cardas Golden Presence IC
    Pass Labs X250
    Martin Logan ReQuests.
    Sep 2003
    Orange, CA
    When Pix was insisting that it took more power to drive a tweeter than a woofer, I listed several models of powered speakers along with their specs, Without exception, every speaker featured a higher-wattage amp for the woofer and a lower-wattage one for the tweeter. Since Pix never responded, I'm assuming that he came to the conclusion that he (just possibly) might be incorrect.
    If you google "bi-amped powered speakers" you'll see what I mean.
