Results 1 to 25 of 36
    Forum Regular karl k's Avatar
    Wichita, Kansas, N America, Sector 001
    Ya, but...
    Do the lights dim? Is the sub amp on the same circuit as the receiver? Are the lights, refridgerator, furnace, ect. on the circuit? I learned along time ago what happens to bass when my cars charging system couldn't keep up. I don't mean long term either. If you don't have the power to supply the amp, it's just about as bad as clipping.(with excessive input signal) I would check it just to make sure before I spent any money.
    Strangely enough, pushing the sub hard hasn't tripped any yet though.
    The amp in question is only 450wt@120v. I have 2ea for my sub(s) and still haven't blown a breaker BUT the lights on the same circuit dim when cranked. I will probably be better off with a dedicated circuit and the amp will probably play better as a result. In my case, getting a better amp wouldn't be any better due to a lack of power to drive it.
    Karl K.
    The shortest distance between two points is a straight line... in the opposite direction.
    Jul 2002
    I don't think there's anything else on the circuit with the amp. No lights dim when I crank it.
    Cool!
    One less thing to worry about!
    Karl K.
