Quote Originally Posted by terraform
I have nothing to sell and am looking for educated feedback. Reside elsewhere, Loser.
Terraform
...you are waxing rhapsodic over a device more suited to a stand alone PC and it's peripherals...
The higher rated (2000-3000va) item is classified as a Class A digital device which by definition is:
Class A digital device. A digital device that is marketed for use in a commercial, industrial or business environment, exclusive of a device which is marketed for use by the general public or is intended to be used in the home.
Further the owners manual states:
Note: This equipment has been tested and found to comply with the limits for a Class A digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference when the equipment is operated in a commercial environment. This equipment generates, uses, and can radiate radio frequency energy and, if not installed and used in accordance with the instruction manual, may cause harmful interference to radio communications. Operation of this equipment in a residential area is likely to cause harmful interference, in which case the user will be required to correct the interference at his own expense.
While the various emphases may be mine, I sincerely doubt any audio-type in the market for the purest of power conditioning will want some ham-handed UPS spewing its RFI/EMI within proximity of his or her high resolution, OFC, Litz-wired, world of wonder.
None of the few owners manuals for audiophile-grade/prosound (PSA, Furman, Monster) power conditioners which I took the liberty to peruse, have any such notices/disclaimers although I freely admit my browse was cursory at best...but...
Given the what seems to the parroting of simplistic ad copy and evincing painfully little grasp re: one of the paramount issues within the land of tweakdom...on your first day of membership no less...surely even you can see how the word shill might be the first thing that comes to mind...
jimHJJ(...although ignorant is quickly rising to the fore...)
