Super duper rack Feanor. A new paint job will really set it off. The adjustable racks are an invaluable touch too.
The only other thing i would have like to have seen is for it to be slightly wider...just wide enough to fit the sonic frontiers item so you could push it back a bit so it's flush to the front of the rack. Pretty picky i know.
Thanks, Hills,
I designed the rack to accommodate standard rack-sized equipment, i.e. inner dimension about 17.5" wide and external with "wings" 19". The Sonic Frontiers is the full 19" even though it isn't drilled for bolt-in mounting. Yep, I could push it back agains the vertical supports.
