My Rega sounds great when the double sided pads are holding the motor in place. The area where the motor mounts is dry and porous and the pad does not maintain contact. I thought I should apply a light coating of Elmer's wood glue to give a better surface for the pad to adhere. Please let me know if this is a good idea or you have a better one. I was worried about the soldering but the real problem is getting the pad to hold the motor. Thanks for any advice.
Try a small amount silicone cement; leave the top off the player for a couple of days so that trapped vapours will be minimal. Wood glue is good for wood and maybe paper, cardboard but nothing else.
Silicone cement has notoriously been used by some commercial component makers instead of brackets & screws for some applications. E.g. Blue Circle Audio did this a lot at one time, but they were so ridiculed that I think they stopped the practice.
