Results 1 to 3 of 3
    May 2004
    Head Shell Leads
    I would like to make some but have not been able to pin down a proper gauge of wire to use. Any ideas?
    You could try tone arm wire. I'd guess about 26 or 28 gage. Since this will not add to the bearing friction as the tonearm moves, flexibility is not nearly as important as it is for rewiring a tone arm so a slightly heavier gage will not matter. You will need a very small pencil iron so that you don't burn the wire up as you solder, tools for manipulating and holding very small objects, and a very steady hand. It may be easier if you have someone to help you. One of you can hold the parts while the other does the soldering. Good luck.
    May 2004
    Head Shell Leads
    Thanks for the input
  1. The Rave Rec'ers head to the New Orleans Jazz Fest!
    By Swish in forum Rave Recordings
    Last Post: 04-26-2004, 12:28 PM
  2. Is that...a crack? A crack in the shell?
    By jasn in forum Rave Recordings
    Last Post: 03-31-2004, 12:22 PM
  3. Head to head audio site
    By surgeandoj in forum General Audio
    Last Post: 03-31-2004, 06:15 AM
  4. Placing my head on the chopping block
    By DPM in forum Rave Recordings
    Last Post: 02-21-2004, 07:02 PM
