Results 1 to 18 of 18
    Aug 2010
    First speaker build
    Hey,
    What would be the best type of speaker to build for a first time project?
    I'm currently studying sound design technology at uni, I'm just about to enter my final year. I decided I want to build a speaker for my final major project.
    But I dont really know where to start, or what would be the best type.
    Thanks in advance
    Roxy
    Jul 2006
    Quote Originally Posted by she_devi86
    Hey,
    Thanks in advance
    Roxy
    sealed box will be easiest, then vented with ports, after you master that, you could start with horns, and folded & backfolded horns, or transmission lines...
    welcome to AR, btw
    Life is music!
    Mcintosh MA6400 Integrated
    Double Advent speakers
    Thiel CS2.3's
    *DIY Lenco L75 TT
    * SME 3012 S2
    * Rega RB-301
    *Denon DL-103 in midas body
    *Denon DL-304
    *Lehmann audio black cube SE
    Marantz CD5001 OSE
    MIT AVt 2 IC's
    Sonic link Black earth IC's
    Siltech MXT New york IC's
    Kimber 4VS speakercable
    Furutech powercord and plugs.
    I'm a happy 20 year old...
    May 2003
    NY
    We have several resident DIY guys here that have made fabulous speakers. What was your price range?
    Audio;
    Ming Da MC34-AB 75wpc
    PS Audio 4.5 preamp,
    Hello she_devi86, and welcome to AR! Just a reminder that double posts are not allowed. I have merged your posts here in the DIY forum, where I felt it best fit.
    There are a few builders here, I'm sure they'll chime in. Enjoy the forum!
    Hey,
    Thanks in advance
    Roxy
    For your first project, best to build a proven design - plenty of DIY websites with lots of great info and excellent designs that are fully documented, including:
    Partsexpress.com
    zaphaudio.com
    http://www.htguide.com/forum/forumdisplay.php4?f=6
    If you had a budget, and speaker size in mind (as well as size of room they will play in) I could make a suggestion or two.
    ISCET CET, FCC CTT, USITT Dual-500's Avatar
    Fort Worth
    What is your cabinet building experience level?
    If beginner, you may want to consider a full kitted project for a starter. Something you do finish work only on the cabinets, plus wiring and driver installation, etc.
    Or pick out pre-made and finished enclosures and select all the components, drivers and crossover(s), etc.
    Parts Express has been mentioned - a good place for a builder to start.
    http://www.parts-express.com/wizards...TOKEN=70747491
    3LB
    3LB is offline
    cunning linguist 3LB's Avatar
    Nov 2005
    If you could please indulge me, describe your major and the extent of your studies thus far. I would be inclined to think you knew a bit about the subject given your education.
    The suggestions laid out thus far are valid. You also should consider what would be your expectation of a speaker; what function would you like it to perform? where will you listen to it? bookshelf? home stereo? home theater? near-field (studio monitor or computer)?
    If you're doing this for a college credit, you might be asked to describe the proposed function and concept of your design, why you chose it, etc.
    We expect a full report!
    You flirt..
    Aug 2010
    Thanks for the welcome.
    price range I really have no idea, lower the better ( i am a student after all lol) i dont really know :s speaker size not huge but not tiny one to fit in to a regular sized room. Not really had any experience building a cabinet, i have to build that myself.
    We've not covered anything about building speakers only how they work and stuff, i wanted to do something different seen as 90% of students do albums. only 5 speakers have been built at my uni and done by girls, so i want to push my self and achieve something i've never done before. Depending on what type of speaker i build it will either go in my bedroom, the front room, or in a friends home studio.
    Roxy
    Fort Worth
    Hello Roxy. I would suggest you build something in the 2-way bookshelf range. Something you can haul around with you in your travels the next few years as you do additional schooling or start a career and move around.
    If it's a requirement that you build the cabinets or simply want to go that route, get someone who's done some cabinet work to assist or mentor you through the build. Otherwise, I suggest buying pre- made or kit (parts cut and you assemble) cabinets as making a square box requires a degree of skill and tools.
    Do you have access to a wood shop at school? Maybe someone there can help you with the basics of building the cabinets.
    Whatever you do - keep your first build. Wish I still had mine just for a keepsake.
    Aug 2010
    I dont have access at school but i do at home, my dad and my uncle have work shops/ garages with tools so can use them.
    Oct 2009
    Colville, WA
    Check out GR Research
    http://www.gr-research.com/
    I would talk to Danny Ritchie and ask his opinion on what speaker kit to use.
    3LB
    3LB is offline
    Nov 2005
    I would suggest a single driver concept, if that were allowable.
    What will be the most important aspect of your project with regard to a grade; should your emphasis be the electric components (cross-over network) or the cabinet design? a bit of both?
    There are some painfully easy projects out there, but it depends on your instructor and in higher Ed, you always have to play up to the instructor. I have assisted a couple of students with similar projects, one being a single driver concept (no cross-over network) but if the project is simple, you'll need to be able to concisely explain the concept to justify it.
    Do you know just what will constitute a successful design where your grade is concerned?
    I'm on my cellphone or I'd post links to make my post a little clearer. I am a long-time builder and have one first prize w/ a single driver concept ('06) and second prize w/ a 3-way design ('08) in the Puget Sound Audio Society semi-annual ameture speaker building contest. Both designs, while researched and studied, were easy and on the cheap (anybody can spend money).
    damn, I done went SirT on this thread
    Aug 2010
    its a bit of both i think. Its a bit awkward at the moment as i don't know the ins and outs of it yet as my year hasn't started yet and wont till the end of september, I just wanted to get a head start/ basic idea/ plan I was goin to do.
    May 2009
    If you are looking for easy and cheap this is your best bet. I've built both the Betsys and a pair of Tang Bands (see my gallery photos) in Open Baffle configuration. Great sounding speakers.
    http://www.wildburroaudio.com/projects.php
    May 2009
    Aug 2010
    I have decided to build a sub bass for my project, I have been informed this will be fine to do as my FMP ( Final Major Project) Reading through the Yamaha Sound reinforcement hand book atm, any other book, papers etc worth reading?
    Fort Worth
    HI FI Loudspeaker and Enclosures - By Abraham B Cohen
    Regarded by many as "The Bible" on loudspeaker design. I used to check this one out from the nearby library years ago.
    It's worth finding a copy and reading it. It will give you the theory of what you are building.
    Make the project much more interesting. It's written at a level a layman can understand - a college graduate student as yourself will have no problem digesting the theory.
    Good choice BTW.
