Results 1 to 13 of 13
    Question Converting Car Sub into Home Sub
    Does anyone have a website or know how to do this and can it be done. Since car subs are a lot less expensive this would be a better option for me. Any help is appreciated thanx Doe
    Yes you can but it would be alot cheaper if you went with a plate amp and a home sub. Go to partsexpress.com and look up Titanic MKII Subwoofer system.
    reply to subkit
    Do you have this sub? which one? Is the 15 better then the 12 and by how much? It says only basic tools required so what tools would I need? Thanks for the suggestion im in looking into it Doe
    Smile Subwoofer
    I do not have one but I am planning on building a DIY subwoofer kit and I consider this kit to be on my top choices. I don't know your listening preference or how big is your listening room. That will help alot.
    You will probably just need a screwdirver and wirecutters.
    room size
    The room will be about 18 ft wide X 20 ft long. I like rock and roll and hip hop but I want a really loud sub to pi ss of my neighbors
    Smile
    Judging by your preferences, I will go with a 15" Dayton Titanic MKII. Thanks
    The Collector
    Sep 2003
    Springfield, MA
    The 15" Dayton will work great if you want it to be loud, but its more than just a loud sub it's extremely efficient and it is a very good sounding speaker. A friend of mine has the 12" one and it sound amazing. He built the box himself though.
    Now if you want really loud go with some EVX-180's in horn loaded boxes and then a ton of power but that is just impracticle and expensive.
    Lightbulb
    Yes, it can be done.
    All you need to play car stereo at home is some kind of a power supply. The cheapest (also, most ghetto) way of "bringing" car stereo at home is to get a computer power supply, and connect the car amp to it. If you're interested in finding out more, post a reply, and I'll tell you how.
    John
    Feb 2004
    Installing car subs in home
    What are all the details for using a computer power supply to wire in an amp? Is it better then other methods using car batteries? Thanks
    The Collector
    Sep 2003
    Springfield, MA
    I would never use a computer power supply for anything audio related, also I would never run a car amp in a house. just my opion though. the reasoning behind it makes no sense to me after the time and the money you could go and buy a good mono block to run the sub.
    DIY Dude poneal's Avatar
    Sep 2003
    TX, USA
    I will let you know how my DIY MKII subwoofer project comes out. Look at my post under speakers called "DIY Subwoofer Update". The box is almost done so the next step, probably next weekend will be to test the sound. Cheers. Paul.
    Feb 2004
    Hi. I'm interested in doing this. I have a 12" car sub just sitting in my garage. If I could hook it up for home use, that would be great. Thanks.
    Talking Sorry folks
    I had not visited this site for a while. I just remembered what I said in the post #8 when I checked my junk-filled email account I haven't looked at for a long time. For those who are interested in using auto amplifier/stereo at home, please email me at darealzg@hotmail.com
  1. home theater amps
    By munawar in forum Home Theater/Video
    Last Post: 12-01-2003, 10:34 PM
  2. Home Theatre Handbook: recommended download
    Last Post: 11-26-2003, 07:22 PM
  3. Best Home DLP Projector?
    By MikeG in forum Home Theater/Video
    Last Post: 11-19-2003, 09:14 AM
  4. Need Help! Home Theater hook - up.
    By shakey in forum Home Theater/Video
    Last Post: 11-17-2003, 09:40 AM
  5. Home Theater
    Last Post: 11-15-2003, 09:47 AM
